Steve K 5 1 Cars Posted October 30, 2021 I've had my 1.6 pepper pots balanced twice now and I still have a horrid vibration/wobble at 55mph upwards from the front and back wheels .... I have driven from Portsmouth to Pulborough today and it has driven me mad! Anyone have any ideas? Or know what donor cheap steel wheels I can use to make sure its def. the wheels. (Like 306 etc). Share this post Link to post Share on other sites
mmt 14 Posted October 31, 2021 Sounds like the tires (tire Walls) are ready to be replaced. How Old are the tires? Share this post Link to post Share on other sites
PhilNW 40 Posted October 31, 2021 (edited) How did you establish the rear wheels are out of balance? The front i guess you can feel it through the steering wheel Have you tried swapping the wheels around, side to side, front to back? What size balance weights on on each wheel? When did the wobble start? had you had some work done on the car? Have you locking wheel nuts on the car? They can cause out of balance even though the wheels are balanced off the car Edited October 31, 2021 by PhilNW Share this post Link to post Share on other sites
Steve K 5 1 Cars Posted October 31, 2021 Hi all, the person I bought the car off had the wheels refurbished and then did re balance the wheels after. I got a good friend to do them and there was still a wobble mainly from the front. I cleaned the wheels up inside as they were covered in mud and got them re balanced again. This time I moved the front wheels to the back and still wobble all round. The tyres are nearly new so I don't feel it's them. My thought process is that if I can get some cheap steels with tyres from another car I can eliminate if it's the wheels or not... Share this post Link to post Share on other sites
Steve K 5 1 Cars Posted October 31, 2021 Should say did not re balance the wheels after the refurbs. Share this post Link to post Share on other sites
PhilNW 40 Posted October 31, 2021 How do sense the wobble at the back? Share this post Link to post Share on other sites
Steve K 5 1 Cars Posted October 31, 2021 I can feel it through my seat and it can be seen slightly at high speeds. Share this post Link to post Share on other sites
PhilNW 40 Posted October 31, 2021 10 minutes ago, Steve K said: it can be seen slightly at high speeds. Slightly worrying if you can SEE IT at high speeds Rather than spend good money on a set of new wheels - You could try making up a simple reference pointer to place up against each wheel and tyre and spin the wheels on the car to check for run out - Try a different tyre balancer and get them to check the roundness/distortion of the wheel and/or tyre with and without wheel weights on the car. I have known it for wheel wobble to be caused by a failing CV joint. Due you feel any tightness when spinning a front wheel? Share this post Link to post Share on other sites
Steve K 5 1 Cars Posted October 31, 2021 No tightness at all. They are all free. Think I might try another balancer and see how we go. Thank you for your help. Share this post Link to post Share on other sites
welshpug 1,622 Posted October 31, 2021 if they have been painted/powdercoated check the mating face, they should be bare metal and spotless Share this post Link to post Share on other sites
Tom Fenton 1,525 Posted October 31, 2021 Hard to find somewhere to balance these properly. They require an adaptor for the centreless wheels and the balancer then should be calibrated with the adaptor fitted before balancing your wheels. This is an easy enough procedure done with a bare wheel and a known extra weight yet they don’t do it when fitting the adaptor usually. Share this post Link to post Share on other sites
Steve K 5 1 Cars Posted December 14, 2021 Hi all, the wobble is all gone now. Got a great garage to do them that had the adapters and she drives like a dream now! No wobble at all! Share this post Link to post Share on other sites
