jerrytug 1 1 Cars Posted October 21, 2021 Hi my 205 needs a new driver's seatbelt and I have ordered one. My question is, can I just undo the bolts from inside the car? Or do you need to get under the car? thanks if you have done this job. Share this post Link to post Share on other sites
Tom Fenton 1,524 Posted October 22, 2021 All is done from inside the car 1 Share this post Link to post Share on other sites
Richard309Sri XU5JA 205GTi 7 Posted October 22, 2021 agreed - all from inside good info. with pictures found in article:- "2) Front belts: remove top pivot point first, remove the bolt cover and undo the bolt.The main retractor can now be removed, this is held in by one bolt to the side of the car. undo and remove belt." On the 309 there is a z bracket on the bottom of the reel but not 205 it seems so the 205 seems easier - 205 there is just the fabric loop at the end connection to the body at the floor level - connected using a bar bolted to the sill. so after doing shoulder level bolt, just undo sill level bolt "unthread" old one "re thread" new one and then re bolt, then reconnect shoulder bolt. Yes undo bottom bolt from inside as per pictures in the article - might need to push seats right forward. Share this post Link to post Share on other sites
SRDT 146 Posted October 22, 2021 The bolts aren't metric and some have low profile heads so it can be challenging if you don't have the right spanner. Share this post Link to post Share on other sites
welshpug 1,621 Posted October 22, 2021 metric head but 7/16-20 threads. Share this post Link to post Share on other sites
SRDT 146 Posted October 23, 2021 On my car 16 won't fit but 17 is a bit loose so it's easy to end up with a rounded head. Share this post Link to post Share on other sites
