Rorykeen 1 Posted March 4, 2021 Hi guys, I went to lower my rear end using the guide on here as it looks really high ? I did one side no problem but the other arm is jammed solid ? Is it new beam time ? I saw somewhere on here the measurement between the nuts on the damper should be around 320mm ? I measured that and both sides were pretty much that give or take a couple of mm but still sitting like this ? thanks Share this post Link to post Share on other sites
welshpug 1,621 Posted March 4, 2021 sounds like you need a new beam if it is seized. did you remove the plate from the anti roll bar then refit it before doing the other side? Miles at pugracing is not too far from you and knows 205's very well, or try Stefan over in Dorset, he does beams too. Share this post Link to post Share on other sites
welshpug 1,621 Posted March 4, 2021 the 320mm measurement is with the vehicle raised and the trailing arm weight taken up, NOT when its sat on the floor... Share this post Link to post Share on other sites
Rorykeen 1 Posted March 4, 2021 Cheers Mei, yeah it was up in the air. I followed the instructions and did one side easily, everything came apart no trouble but the arm just won't move ! I think I'll just get it off and rebuilt cheers Share this post Link to post Share on other sites
jord294 87 Posted March 6, 2021 Have replied to your pm Share this post Link to post Share on other sites
Rorykeen 1 Posted March 6, 2021 Cheers Jord, could anyone confirm some brake part numbers for me please ? 41427p for brake shoe kit, and drums 424731. Thanks Share this post Link to post Share on other sites
jord294 87 Posted March 6, 2021 Thought the rallye had 30mm shoes and drums? Share this post Link to post Share on other sites
Rorykeen 1 Posted March 6, 2021 I’ve got a spare set which came with the car at 30mm but the ones I’m taking off are 42mm the pistons are seized up, so I’m just going to swap the kit including drums and bearings.....but I can’t figure out what I need ! Share this post Link to post Share on other sites
jord294 87 Posted March 6, 2021 Gti spec then. I have genuine drums and complete brake kit if you're feeling flush Share this post Link to post Share on other sites
Gohn 62 Posted March 7, 2021 at the risk of just confusing the issue i've attached the part catalog pages but you seem to know what you're after (think maybe the rallye gets the TU24 spec drums) Share this post Link to post Share on other sites
DamirGTI 323 Posted March 7, 2021 Proper euro TU24 Rallye has 1.6 GTi suspension .. front and rear . D Share this post Link to post Share on other sites
jord294 87 Posted March 7, 2021 13 hours ago, Rorykeen said: All new Andy ? Brand new and genuine peugeot parts Share this post Link to post Share on other sites
Rorykeen 1 Posted March 7, 2021 Cheers guys, appreciate the help Share this post Link to post Share on other sites
