HoRSiCZeK
75kw lambda sensor replacement buy tip
HoRSiCZeK
Hi there guys,
please does anyone have some tip for right lambda oxygen sensor replacement for 75kw Jetro? This part is quite expensive at CZ, so I was looking for some on ebay, but there is ****ton of them and dunno which choose...
If there is any, can someone please post a link for exact part or some ebay verified shop where is good to buy from?
Thx for any advice!
HoRSiCZeK
ofc I am looking for OEM replacement, I do not want to go with some universal oxygen sensor, thats why I am asking
DamirGTI
OE O2 sensor is from Bosch : 0258003046
Around 100EU +/- depending where you're buying and if you have a parts discount ..
Bosch , NGK , Denso is what i would look for OEM type with the connectors .
Look around here : https://www.autodoc.de/search?keyword=+0258003046
They seem to have the lowest prices ... not sure about ebay , personally i'm not much of a fan buying car parts on/from ebay .
Anyhow , if you're on the budget , i'd go for the Bosch universal :  0258986502
https://www.autodoc.de/bosch/1149526
Fitted a few of them on various (much modern/engine management demanding) cars and no complains , fuel trims all good up the specs .. only thing to note you really must use the connector supplied in the kit and follow the instructions , do not solder wiring on this sensor .
D
HoRSiCZeK
D
thank you very much Damir! you summed everything I needed to know about it ( I was going to ask about soldering in next step :) ) thx again!
