Gary C 0 Posted July 28, 2020 I'm sure this subject has probably been done to death but I have just bought a 1990 205 gti 1.9 it has had a quafe LSD fitted, 309 gti drive shafts, 309 gti lower arms, 309 gti anti roll bar, new anti roll bar links, Gaz coil overs, new track rod ends . New rear beam, new bearings, seals and bushes, and gaz adjustable dampers. However the steering and handling is appalling, especially at low speed, as in turning off of my drive, or parking, it clunks, tries to pull the steering wheel out of your hand on lock, sounds like somethings lose ( it isnt). I wouldn't dare drive it at speed to be honest, it just doesn't feel safe, its vague, you don't feel properly connected in any way. Ideas folks? Share this post Link to post Share on other sites
Tom Fenton 1,524 Posted July 28, 2020 Oval front hubs would be the first place I would look. Where the pinch bolt arrangement clamps to the wishbone ball joint. Share this post Link to post Share on other sites
Gary C 0 Posted July 28, 2020 10 minutes ago, Tom Fenton said: Oval front hubs would be the first place I would look. Where the pinch bolt arrangement clamps to the wishbone ball joint. Thanks for that, yeah I thought it might be hubs, new hubs if thats the case then? Share this post Link to post Share on other sites
Ozymandis 96 Posted July 28, 2020 If it is, they can be sleeved , Bridgecraft in Derbyshire can do it ,ask Allen Allen on here. 23 minutes ago, Gary C said: Thanks for that, yeah I thought it might be hubs, new hubs if thats the case then? Share this post Link to post Share on other sites
wicked 103 3 Cars Posted July 29, 2020 (edited) 2nd thought; too long LH 309 driveshaft, having no clearance on tight corners and hitting the diff? Edited July 29, 2020 by wicked Share this post Link to post Share on other sites
Gary C 0 Posted July 29, 2020 2 hours ago, wicked said: 2nd thought; too long LH 309 driveshaft, having no clearance on tight corners and hitting the diff? Thank you I will also mention that to the guys. I am taking it to Pug1off on Friday, hopefully they can sort it out. Share this post Link to post Share on other sites
