Philip
How can I tell if my rear brake pressure regulator valves are working ?
Philip
Swapping all the brake lines and flexi’s for new , pressure regulator things are off the car and on the bench , but rusty on the outside but the inside looks good, the internal threads and the face the pipe seats on are both as new.
Car has be in dry storage for last 10 year’s , all the pipes and fittings are badly corroded. Is there a way to tell if the compensator is okay before I put it back on the car don’t really want to have to fit it get to the MOT station and find out I should’ve swapped it.
whatever is inside it appears to be in the open position as you can blow through from both ends , not really sure what Is inside Or how it works so not sure if this is a good or a bad thing
thanks
you could hook it up to a master cylinder and a caliper with a pressure gauge, from memory the 205 valves are rated at a 20 bar knee point, i.e they will ramp up to 20 bar then flatline
Philip
What do they do actually ?  Do they restrict the flow of fluid to the rear or completely block it until a certain pressure is applied to the pedal?
Or do they step down the pressure so less force is applied ot the rear pads than the front ??
All the above are guesses
boldy205
As they are off the car already I think id just replace them,l. They are a common item to break down. I presume they are still easily obtainable.
Matt
Philip
Matt
£100 a pair !!!
hoping not to replace if I don’t have to
Leslie green
I guess its just a ball and spring inside not much to go wrong really ,if they have been in fluid they should be ok
Ozymandis
Soak them in some meths and give em a good shaking about with clean meths, blow air through and that's all You can really do, make sure theres no crap in them.
They fail, because of old /contaminated fluid causing internal corrosion.
https://www.youtube.com/watch?v=7Pa8J2V67rA
