boldy205 74 Posted September 22, 2019 Hello people I'm in need of a pair of two piece disks in 306 Gti6 size. I've contacted a couple of suppliers, just wondering if you had and recomdations/suggestions? Thanks Matt Share this post Link to post Share on other sites
welshpug 1,621 Posted September 22, 2019 ben at godspeed brakes can help you, knows pugs very well, are you after the same offset? Share this post Link to post Share on other sites
boldy205 74 Posted September 23, 2019 Thanks I'll give him a call. Pretty sure it's the same offset, I'll trial fit it all and see what I have . Pretty sure its GTI6 disks, I'll look up the specs Share this post Link to post Share on other sites
wicked 103 3 Cars Posted September 23, 2019 Did you already encounter a supplier that supplies 2 piece discs for the common 302mm discs (424980) as used on 307,308, DS4, DS5's etc? for decent money? Or the smaller 283mm (424984) (non GTI6) as used on 207/307/C4's etc? Share this post Link to post Share on other sites
Batfink 201 Posted November 26, 2019 Theres not a lot of weight to save with the GTi6 discs due to the very shallow offset. It all helps though and vastly depends on the thickness of the new disc and how many vanes it has. Share this post Link to post Share on other sites
boldy205 74 Posted November 26, 2019 On 9/23/2019 at 1:13 PM, wicked said: Did you already encounter a supplier that supplies 2 piece discs for the common 302mm discs (424980) as used on 307,308, DS4, DS5's etc? for decent money? Or the smaller 283mm (424984) (non GTI6) as used on 207/307/C4's etc? Just saw this thread had a few posts. Aren't the GTI6 brakes 283mm dia? Share this post Link to post Share on other sites
wicked 103 3 Cars Posted November 28, 2019 Yes they are but the disc itself is a bit thinner than the more common 283mm discs as found on 207/307... Share this post Link to post Share on other sites
