Ojm25weobley
Looking at a 1.6GTi
Ojm25weobley
Hi all,
I am a keen enthusiast of the 205 GTi and the opportunity has come up to buy one off a friend for a project.
The car is red and has a sunroof, original interior and no modifications that I’m aware of.
The car needs work.
I am looking at keeping the 1.6 in there and keeping the interior.
What modifications would you all recommend. I don’t mind spending a bit but don’t want to swap an engine. Happy for cams, throttle bodies, or any suggestions.
please advise :)
You can spend a lot of money modifying an 8v engine and you wont get much power in return. Unless you turbo it...
E.g.
Ojm25weobley
E.g.
Many thanks for the reply. I’m not looking to turbo or anything quite like that. Little increases suit me to the ground.
Mainly want it to sound the part and pull the best it can. I like the sound of the rough idle from cams and that sort of thing. Any ideas mate?
Individual throttle bodies sound amazing, fit some of them and a lairy cam and it will sound great. just don't expect more than 10-15% extra power and be prepared for that little bit of power to cost a lot of money.
Telf
keep it original.. that's what I say!
Telf
well apart from the engine management maybe... :D
Ojm25weobley
Hahahaha good shout :)
Telf
ive swapped mine to emerald- expensive but I think worth it
Ojm25weobley
Is this the ECU? Have you left internals standard then?
Telf
yep- and no- it has no dizzy,tacho relay,AFM or ignition amp - all removed. the emerald ECU manages it all via a few sensors
Telf
and you need to replace the engine loom as well
SRDT
There was a 125hp kit for the 1.6 105:
The head looks like a BX Sport one so a 115/130 head should be as good, if your 205 is a 115 you need the camshaft and spark plugs with a bit of work on the head.
It's not the best but it has this period correct feeling.
Telf
so did you buy one Oli?
Ojm25weobley
In the process yes :) still unsure what to do. Going to get it running standard and then go from there I think
camgti
To be honest the first things I wohld do to an1.6 is
Fit power steer from a 1.9 or xsara. Someone who knows what they are doing will have no trouble doing this properly.
Get decent pads or fit 1.9 calipers and discs.
Fit a quaife diff if a road car. 1 for i surance on the box and 2 youll enjoy it more!
A 1.6 with more conpression, cam and some throttle bodies would be a nice engine with the above mods. Mind you it will cost 3-4 thousand pounds to do all this properly. (The above included)
The other fists wohld be to rebuild the rear beam and refresh all the suspension bushes if they are old or worn. 205s really are terrible to drive if they are not right.
You dont need more that 150hp in a road 205 to go fast. They are not traffic light drag cars by any means. Get them in the turns and they will really suprise you.
