Naj
Hi All,
I have just recently brought a 1989 1.6 GTI and have noticed that there is an issue on idle, it seems to struggle and cuts out, the only way I can keep it going is by giving it some revs.
Im sure many owners may of had the same problem so I am hoping somebody can point me in the right direction before I send it to a garage.
Many thanks in advance.
Naj Kumar
Edited by Naj
Spelling errors
boldy205
When it's hot, cold, or both?
Cold may be the SAD (supplementary air device). Have a Google, loads on it.
Naj
Hi,
Does happen when hot or cold.
Its had a brand new air flow meter and everything.
Alot of people keep on mentioning a valve at the bottom of the engine?
Check the throttle initial position is set correctly as detailed in the Haynes -
Also make sure the throttle body and related hoses are clean, take the idle screw out and clean it until it is spotless.
