Adamstanford
Damp near a pillar!
Adamstanford
Noticed when getting in the car this morning water dripping from the a pillar trim drivers side. The headlining at the top of the a pillar trim is wet, near the windscreen and right up to the door seal, about a fingers width.. What is a likely culprit here? Door seal or windscreen seal? Thanks
Adamstanford
Found it. Seems to be some rubber tab, possibly where the lining of the sunroof trim goes into the roof.. Will pull more out tomorrow
That's the sunroof drain tube that takes water from around the sunroof and drains it down to the floor
Callum
The seal between the roof and sunroof frame is leaking on mine might be worth checking yours while the headlining is down
Adamstanford
It's that little rubber bung above the tube that's leaking. Don't know it's purpose!
Callum
What's on the otherside of the bung? Mine doesn't have that perhaps it's a hole where an after market wind deflector had been fitted then the hole was poorly sealed off
AlexRS2782
Same here - looks like the recent cold snap finally finished off the seals on the frame on mine as the headlining is soaking :(
Always had a small amount of water ingress in heavy rain but it's wet as anything now - yet another job added to the ever growing list.
Callum
I've got this to replace it;
Edited by Callum
