Iansurf
Fitting new valve stem oil seals
Iansurf
What’s the preferred method of installing new valve stem oil seals , cylinder head is off the car, I’ve had re-order some more as I managed to mangle a couple.
DamirGTI
Clean and oil up the tops of the guides (use engine oil) , oil up the seals as well , tool wise i use small long socket extension with an 11mm socket on the end to press on the seal on the guide , firstly just by hand then tap lightly with smaller/low weight hammer .
D
Iansurf
Thanks Damir will give that a go when I get my new seals.
DamirGTI
It's an easy operation really , just oil up all the seals (bottom side especially) , an dab of oil on the guide tops , fit the seal oiled up into the socket (must be 11mm , so it seats on the metal part of the seal rather than the rubber area) , and be gentile , don't bang them hard with an hammer ! you'll be able to check them visually after the install , if one or a few look higher/level off just tap them some more so they seat on straight .
"The tool" i use ! (fitted the seal inside can see it on the pic) :
26625491961749e64e64af166a41b2cb31ff2e02
Have fun !
D
Similar method but I’ve a lathe on hand so made a tool to suit.
DamirGTI
Would love having an lathe too Tom !
..there's so much thing that can be done/fabricate on a lathe , especially for us having/working on old cars and doing some "weird stuff" with them !
D
Iansurf
Yep I was little heavy handed lesson learnt
DamirGTI
Practice makes perfect , don't worry , most of us we've all gone through the same process "bend and mend" !
D
