SteveD205
Top Engine Mount
SteveD205
Is there a technical document anywhere on how to chance a top right Gti Engine Mount , its loose but I can't see how it un-does and come out ?
It just unscrews, you'll probably need to use a chisel or something on the edge to get it started.
There is a special Peugeot tool that locks onto it and lets you undo it with a socket wrench but you don't need it.
SteveD205
Thanks , its very lose and was worrying about sheering it off , I'll give it a try .
it goes into a captive (caged) nut so be careful not to dislodge that, if it was already loose the captive nut might be a bit compromised.
