Telf 232 2 Cars Posted January 5, 2018 As part of my on going work on the Pug I'm going to refurb the front and rear calipers. I'm wondering if anybody can give me an idea of the likely cost to do this and availability/ difficulty doing the job Cheers Paul Share this post Link to post Share on other sites
dcc 855 Posted January 5, 2018 Rear calipers are not fun to do. Probably better getting a refurb set! Seal kits were around £15/caliper last time i checked Share this post Link to post Share on other sites
Telf 232 2 Cars Posted January 5, 2018 I've been quoted £500 to do them and paint ... seems excessive to me! What's the issue with the rears? Share this post Link to post Share on other sites
Tom Fenton 1,582 Posted January 5, 2018 The rears are a c*nt to do, there’s a strong Belleville to compress, there must be some special tool to do it, it can be done without but it’s a faff. Personally the only trouble I’ve ever had with rear calipers is bust bleed nipples or the dust boot torn. If I was doing it I’d mask up and bead blast the alloy bit, fit a new dust seal and bleed nipple, and have the cast pad carrier blasted and re-plated. Fronts are much easier, the time consuming part is having them re plated really. The rebuild is straightforward. Watch out for the 5-sided cap head bolts holding the calipers halves together! 1 Share this post Link to post Share on other sites
Tom Fenton 1,582 Posted January 5, 2018 Not the best pic but here are the fronts I did. Share this post Link to post Share on other sites
farmer 328 1 Cars Posted January 6, 2018 I bought some motorfactorold stock Got some rear offside calipers with carriers for a 205 Would sell one if it helps on those ? Share this post Link to post Share on other sites
Alan_M 66 1 Cars Posted January 31, 2018 When I rebuilt my rear calipers on my now defunct 306, I used an old attachment off a valve spring compressor tool. Along with a small G-clamp, the washers compressed nicely. The old Citroen ZX diesel Haynes gives a good guide on rebuilding rear calipers. Share this post Link to post Share on other sites
ALEX 98 1 Cars Posted January 31, 2018 Have you tried Biggred? http://www.biggred.co.uk/ Share this post Link to post Share on other sites
