Deantracy17
15 minutes ago, Deantracy17 said:
Cheers telf. Used your 8v rebuild a lot during my rebuild. I’m nearly there. I’ll take a photo of the issue I have. I think there is a separate spacer. The sprocket with spacer combined is the oil seal. I was wondering what stops the sprocket from moving around during operation. Maybe the chain keeps it in place?  My engine is a xu5ja. Hopefully it will all go back together ok.
also bought some goetze rings. The top two have “top” engraved on them, but the oil ring does not?  I assume that this goes either way?  Can you remember when you did yours?
Telf
I think I asked the question about top when I built mine. They do go with top facing up. The others it doesn't matter as I recall. In the haynes there is a diagram showing the correct orientation.  Scroll back im sure I covered this point.
Telf
On 1/26/2018 at 5:30 PM, Telf said:
you can see the fitment more clearly on this pic
Telf
have you locked it in place with the woodruff key?
Telf
Ref the rings as per page 11 of this build thread that how i fitted them
