lemmingzappa
Xu10J2Te Throttle Body Gasket
lemmingzappa
I've been trying to source the correct gasket for my 2.0 8v Turbo throttle body which looks like this:
Photo%2013-04-2015%2018%2049%2010_zpsy3g
On Servicebox I can't find the correct part. This is all I can find:
Photo%2016-04-2015%2022%2042%2024_zpsosb
Number 3 which is a rubber ring (incorrect) but shows the correct 3 bolt flange. Part number 0365 32.
or
Photo%2016-04-2015%2022%2027%2022_zpsvmq
Number 21 which is a gasket, but shows the wrong 2 bolt flange. Part number 1635 58.
I would just get hold of some gasket paper and cut out one yourself.
The drawing on Peugeot Servicebox under 406 looks correct for that second part number you listed.
Listed as £3.37 inc VAT and doesn't say it's NFP (unlike the later seal, which is NFP)
lemmingzappa
Thanks Ant! It seems there are many variants of this engine.
Edited by lemmingzappa
I think there's only fundamentally two different variants of the engine, RGY and RGX, but there will as always be detail changes with wiring, pipework and ancillaries depending on which car it was sourced from.
Servicebox isn't infallible and sometimes you'll find diagrams or listings that are wrong under one car but right under another - hence the diagram showing a two hole flange on the Citroen one you listed to when quite clearly that's not the case!
The diagram is a bit wrong for the XM by the looks of it, same part number though, 1635.58.
cheesegrater
Alternatively a smear of sealant would suffice.
