dale205mills
[Car_Overhaul] 205 Gti Front Panel Replacement And Underside Restore W
dale205mills
The front end of my 205 looked about the same, but I managed to make a very nice repair panel for the inner wing. keep up the good work.
Thanks for the kinds words, the front end was rotten and split all the way up to the front shock mounts and with the washer bottle covering one side and a big fuel filter for my gti6 engine where the jack used to be a lot of it is out of site, the car is being built as a fast road car with trick bits and driven unlike my silver 205 which is a garage queen.
dale205mills
I have been able to do some work on the topaz over the week end, I have painted up my front hubs and trailing arms in black and my rear beam in glow in the dark yellow, I have all so blasted and cleaned all my bolts from my running gear for zinc plating and cleaned up stuff for the powder coaters.
fronthubsandreartrailingarms6_zps6a03ccbâ€fronthubsandreartrailingarms7_zps4db7a83â€fronthubsandreartrailingarms5_zps0972009â€fronthubsandreartrailingarms2_zps6b06f6dâ€fronthubsandreartrailingarms3_zps1762603â€fronthubsandreartrailingarms1_zpsa32c34fâ€fronthubsandreartrailingarms4_zps5b5c43eâ€rearbeampainted_zpsbdd6face.jpg​‹‹‹‹‹‹‹
mowflow
Good work. I'm in the process of or about to do a lot of this stuff myself.
What paint did you use for the trailing arms? Looks nice and thick.
dale205mills
2k Black, painted using a paint gun, nice and hard wearing paint.
dale205mills
Bit of a update, re angled gti6 manifold turned up today, all the small brackets and bits that I blasted at home are at the powder coaters, all of my running gear bolts are ready for re plateing and I have just painted the bottom end on my gti6 engine in black, I will be paintingthe head in a few days after I have got some masking tape.
gti6bottomend_zpsf20efe36.jpggti6bottomend2_zps5f5642d5.jpgâ€gti6bottomend4_zps6b07ac13.jpggti6bottomend5_zpsf1b52ce9.jpgâ€gti6bottomend_zpsf20efe36.jpg​‹‹
johniban
im in the same process of repairing my front wings, im making a right meal of it
dale205mills
Bit of big update I have got all my bits from the powder coaters back all looking good and shiny and I don't think I will ever paint my bits again at home after seeing how well the bloke done and how cheaper it worked out then me doing it at home or in the oven at my mates body shop, soon as I start up warping I will post pictures up. I have had a week off work to do some work round the house and paint the engine bay on the 205, what started as a quick engine bay paint has ended up with a full front end re paint ie bumper, bonnet, grill, front wings and engine bay. The bumper, grill and bonnet were painted in the oven and engine bay and wings at home, I will be painting the wings again in the oven as I am 100% happy. I have got photos of engine bay and I will try and get pics of the other bits some time in the week.
paintedenginebayoctober_zps358b208b.jpgâ€paintedenginebayoctober2_zps18055f21.jpgâ€paintedenginebayoctober4_zpsbb38c9ce.jpgâ€paintedenginebayoctober3_zpsfcd8e0f7.jpgâ€paintedenginebayoctober5_zps0a4412c9.jpgâ€paintedenginebayoctober1_zpsb1446aca.jpg​‹‹‹‹‹
dale205mills
I have been busy over the weekend running the engine bay wiring loom, I have decided to run it a different way to try and some ideas for my red one, there is some wires to be soldered to tidy the joins up as we all no french electrics can be brittle after time and I will heat shrink them for a nice uni form finish.
enginebaywiring1_zps6ca92c2d.jpgâ€enginebaywiring2_zpsbef969b8.jpgâ€enginebaywiring3_zpsabcd2187.jpgâ€enginebaywiring5_zps3ebb89ff.jpgâ€enginebaywiring4_zpsdd89891d.jpgâ€enginebaywiring7_zps2c465780.jpgâ€enginebaywiring6_zpsf2af36aa.jpgâ€enginebaywiring8_zpsabe611bc.jpg​‹‹‹‹‹‹‹
dale205mills
Bit of a up date, started to do a few more bits on my topaz 205.
topaz205november5_zps6ee955bf.jpg​
topaz205november1_zps26a46aa8.jpgtopaz205november2_zps12500e7a.jpgâ€topaz205november3_zps3e872c6e.jpgâ€topaz205november4_zps97db92c9.jpg​‹‹
dale205mills
And some more
topaz205november6_zpscf2f050f.jpgâ€topaz205november8_zps533c305d.jpgâ€topaz205november9_zps796a5895.jpgâ€topaz205november7_zps52fe0819.jpg​‹‹‹
cybernck
Great work, as usual. Any updates? :)
dale205mills
I have put the rear beam together and that is about it really as I have another big project on the go and that is a new home for my silver 205, I will let the photos do the talking and this is where my money has gone.
garagewallsingray3_zps73a038e6.jpgâ€garagewallsingray1_zpsc422c895.jpgâ€garagewallsingray2_zps661243bc.jpg​‹‹
dale205mills
I think it is time for a bit of a update, with us having a nice summer this year and me trying to Finish my garage and recovery truck and putting a 3 door RS Cosworth back together, the Topaz has been left in the workshop and forgotten about but now the winter is here, that means 205 time.
firstcoatofpaintonceilingandwalls1_zpsa4
firstcoatofpaintonceilingandwalls2_zps27
10600532_988241214525371_683602208266441
1919673_988253234524169_8168181411609618
Now we will move on to the proper stuff
10636587_10152797737808255_8729480316469
10644534_10152797738253255_7279985595688
dale205mills
Sundays work. all that is left is Fit cam belt and water pump, Fit Oil pressure adapter which is on its way from Miiles(Pugracing) and I will be be ordering a bottom solid pulley soon from him. I have fitted diff bearings and the box will be back together in a few days, then engine and box will be fitted.
dale205mills
starting to collect a lot of parts here and there to get it rolling again, I have fitted the engine and box today.
dale205mills
Bit of a update, wireing loom fitted and sensors that needed changeing are done, wishbones, droplinks and new front wheel bearings where fitted today.
20150418_192903_zpsrsltbjn2.jpg20150418_192852_zps3jjb7pyl.jpg20150418_192842_zpsbysqbyrd.jpg20150418_192821_zpsiaiavz5g.jpg20150418_192806_zpsmi88x4kj.jpg
dale205mills
Bit more done today, loom and manifold in today and I have had a bit of a dry run with a few things in the engine bay to see how every things fit and look.
20150419_202242_zpsod65hlwj.jpg20150419_202234_zpsrhcgbhwc.jpg20150419_202215_zpscimukapm.jpg20150419_202204_zps6ccind04.jpg
dale205mills
Bit of a update, I have built up my front end tonight.
20150704_222320_zpsixadbsqp.jpg20150704_222329_zpsnnwkdefy.jpg20150704_222445_zpswfc3sec2.jpg
dale205mills
I have had my baker hoses turn up
New gti6 disc and pad for front and normal 1.9 for rear
new hand brake cables
oil cooler
brake rebuild kit
Leon
Nice work, was it difficult removing and replacing the headlamp panels with the wings still in place?
Looks good - certainly a damned sight tidier than my Topaz!
I might be wrong as it's quite small on the picture, but haven't you got two oil pressure guage senders fitted, rather than a gauge sender and a warning light switch?
