350wedge
Airbox Bracket Bolt Size?
350wedge
Quick question chaps....
The bolts that attach the standard airbox bracket to the exhaust manifold....
Am I right in thinking these are M7 in size? Just fitting a new airbox with bracket but the bolts are missing from the manifold..
Many thanks :)
Ryan
M6 according to Servicebox.
350wedge
I've tried M6 and they just drop straight into the hole!! The top mount on the end of the box is M6 but the manifold holes are bigger. They are not M8 though as I have those and are too large...
They are M6, but quite often the threads in the manifold are u/s. You could carefully helicoil them back to M6.
farmer
did you buy the new bracket the one of ebay ??
350wedge
No I got a refurbished airbox which came with an intact bracket. The bracket and box are powdercoated so that should keep me going for now. If I need another I have the old bracket which I can copy at work and fabricate a new one :)
350wedge
Quick update to this....
Have got hold of some nice shiny new M7 bolts and they fit perfectly into the manifold where there bottom two bracket holes are....
The bolt hole at the top of the engine is an M6 but the manifold bolts are M7
farmer
yeah found out there M7 to mate the other day
As you have found, Most are M7 but there are a couple of M6's but these are quite rare
farmer
Miles would you recommend using stainless steel to bolt bracket to manifold
350wedge
Good old French eh, using random size bolts ;)
If you can find a stainless M7 bolt then yes, Brass is just as good but again the size buggers it up
