peter
[engine_work] Budget 16V Turbo In Laser Green
peter
Ive always wanted a 16v turbo 205 but have never been loaded to buy a DP manifold or a t16 engine.
So ive made one :D
I figured if i could make a 16v turbo manifold the rest would be easy...
I didnt have much to start making it with, apart from a 318is exhaust manifold so i chopped and welded that to look somthing like a DP one then bought a 306 gti manifold off ebay for £1 for the head flange and the 4-1 collector welded these on and it was done.
ill get some pics up asap!
omega
we need to see this
have you tested it yet?
peter
Just uploading some pics to photo bucket....
First attempt at the manifold, not equal length and on of the runners fouled the gear linkage.
peter
this one clears the linkages and is almost equal length
as you can see i gave up grinding the welds back half way through
peter
peter
cheeky one of the car
M@tt
Good effort mate!!!
peter
cheers mate! this is what the manifold looked like originally
StuF215
Thats a class job there well done,
Makes me wish I still had a welder i'd love to give something like that a go although im guessing it wouldn't look quite as good :lol:
peter
but i needed an engine for the manifold, luckily one came up opn here (thanks robturbo)
£150 later i had a rebuilt 8v turbo bottom end s16 pistons -1mm off the top amd a gti6 head. BARGAIN. sort of, ill explain later...
Oh and a volvo turbo TDO4-HL16T apparently from a t5r?! bargain again at £30
custard-rallye
looks good nice mani
calvinhorse
Awesome! This is more like it!!!! :)
pugdamo
Good effort,ill be following this one,loving the laser,looks just like mine :D
peter
Fitted the home made manifold onto the gti6/8v engine and it didnt fit....
I built the manifold up on a scrap mi16 which has a different thermostat housing. So had to modify the thermostat on the gti6. Welded 38mm alloy tube to it, seems to work! You can just about see the end of it here.
Motor in and it fired up first click
No smoke from the breathers or out of the exhaust idles perfectly!
After a bit of faffing about welding the downpipe and bolting the turbo on its complete! Yes its rough with horrid blue and red vacuum pipe but its all i had at the time...
Did someone say time for a test run??
Edited by peter
peter
Test drive was massivley dissapointing!!
Any more than half throttle and the car would almost cut out. At first i thought it was overboosting and getting fuel cut but It did this even when the was no boost at all.
After doing less than 5 miles of feathering the throttle and the car cutting out it started to run on 3 cylinders, opend the bonnet to find smoke pouring out of the oil breather. Oh dear ive melted the pistons already!! or could it be the headgasket or turbo? Theres no chance it could have melted the rings or pistons it didnt even have half throttle for more than a few seconds.
So bought another turbo, my reason for thinking it was this is that there was a crack in the housing and i though exhaust gas could be going down the turbo drain and into to sump causing crank case pressure. But nope that didnt help!
It must be the head gasket somehow letting cylinder pressure into to the crank case. Head off then...
Turbo and inlet take about 15mins to remove! You can see the cossie intercooler here
Then head off after another 15mins!
Head gasket looked in poor condition and the pistons looked fine.
New head gasket and back together....
peter
While i had the head off that time i thought i would try and find out why it didnt like any amount of throttle position.
This was quite easy measured the resistance of the gti6 TPS at different positions and found its backwards to normal!! drilled a hole through the centre and mounted like this problem fixed!
peter
After putting it all back together with fingers crossed...
Started it up and it was still sounding like a clapped out impretza with smoke pouring from the oil breathers, for ****s sake i nearly kicked **** out of it and set it on fire!
Sensible thing now do a compression test....
100 psi 40 psi 50psi 160psi
Well theres the problem, piston rings nackard after 5 miles. Head off again!!! good job it only takes 30 minutes!
Pistons out, can anyone see the fault?
peter
Found the reason for the low compression....
Looks like i need a new set of pistons :(
peter
got a set of 8.5:1 pistons from an 8v turbo filled two slots into them for the 16 valve head to clear honed the bores and fitted a brand new set new set of rings that cost £90!!
Gave the head a quick port too, similar to the intake on a e36 m3 inlet port now
This time no smoke from the breathers it runs on all four cylinders and sounds CLASS!!!!
After a few hundered miles of running in time to open up the throttle.....
OH MY GOD!! On the lowest boost setting 0.4 bar its BALLISTIC! half throttle it pulls to the limiter in 5th :o
Keeping an eye on the AFRs with this...
The AFRs seem to be ok at this boost setting it leans out from 11 to about 12.5 at 6000rpm
Unfortunatly there is still a occasional misfire.
New set of spark plugs from a EVO BPR8ES apparently people run these on supercharged gti6s but they dont fit without quite a bit of sanding :lol:
8v turbo plug modified EVO plug Standard EVO plug
They now have a 17mm head and fit fine.
Daviewonder
I'm liking these quick updates, so much better than real time updates.
What management you using?
peter
mp3.1
Just turned the boost up to 0.9 bar wich made it run a bit lean top end so have fitted a FMU. trying to get it set up spot on.
Unfortunatly though its developed a very loud high pitched rattle that is not related to engine rpm. It sounds so bad people run away from the car :blink: sounds like its around the starter area. Might be vacuum pump?
yippeekayay
subscribed, spent the last year trying to restore a 1.9 Turbo technics to original TT spec and hit so many problems I went omex.....Though mine sounds a lot simpler than yours. Mine torque steers like an absolute mother at 196bhp 210 ft lb at .9 bar so yours must be monsterous.
keep it coming.
peter
at a gess mine is around 200hp
It does leave a dyno proven 241hp octavia standing still at 0.5 bar boost but i really need to fix this rattle :(
Get it set up right then, mine drives arrow straight under full shove with similar numbers.
