luchjeg6
My 1.9 Won't Start.
luchjeg6
changed engine due to bearings gone on the old one. The car used to start when I bought it broken.
now I changed engine and there isn't the spark at the plugs. Neither from the coil. What could it be? iWhat should the cables of the socket going in the coil be?
dcc
check the lead from distributor to ignition amp
Matteo
I would also try with a known good ignition amp.
luchjeg6
the lead? it used to work before taking off the engine, I tried with other 5 ign amplifiers and no spark. Do you know what is an additional cable from behind the socket OF THE COIL going into the cockpit?
