omri617
Air Filter In Box
MiniGibbo
What you looking to do, fit a aftermarket cone filter into an oem box Honda integra style..?
BlueBolt
Looks like he just wants to replace the air filter for another standard???
flipperthebushkangaroo
Looking on E-BAY you can get an OEM style K & N which has the following dimensions.
Part Number: E - 9000
Product Style: Round Air Filter
Height: 9.5 in (241 mm)
Inner Wire: No
Inside Diameter: 2.875 in (73 mm)
Outside Diameter: 4.438 in (113 mm)
Top Style: Open
The inner is slightly smaller on the one you mentioned as is the outer. this would suggest ( If K&N got it right) that the one you linked to would be a bit loose?
Roddie
AlexRS2782
The K&N E-9000 part numbered item mentioned above will fit fine in the standard airbox - i've had one in mine the last few years and it's been fine. Just give it a yearly clean off :)
Edited by AlexRS2782
omri617
thanks a lot.
gavbrum
K&N E-9000 Going for £26.37 on eBay.
Just got myself one. Seems like a bargain.
