calvinhorse
Base Model Front Arb 'setting'
calvinhorse
I've just swapped my front arb to the larger 205xs arb (absolute nightmare of a job)
Just wondered how to set where it sits as it can move a good 20mm and would drastically alter where the wheels sit, is their a technique or is it just a case of measuring from the subframe to the tip of the arb?
In the Haynes book there is a diagram with a measurement to set the clamp bar.
allanallen
Or just fit a gti subframe and wishbones..... :P
Engine in?? Is it fast??
calvinhorse
Cheers Tom never thought!
Yes engines in, runs nice and the power is erm novel!
BERTMAN
get rid of the horrible base model set up!! I've got a GTi subframe with a TU linkage welded on and some GTi wishbones for sale... :P
what engine are you running?
Don't encourage him for fecks sake!! This car is supposed to be the economical runabout!
calvinhorse
nothing wrong with basemodel tcas!
I'm running your old xs engine which seams great! Gearbox whines a bit, think it's the input shaft bearing. I'm not complaining the box was free!!! Cheers bertman!
steve@cornwall
Hey, we've all been there :D my cheap runabout is COMPLETELY standard.........
BERTMAN
I can't stand it, pain in the arse to work on and the tca i seem to get hold of wear out in months.
no problem, they are great little engines :)
