Guest rodneyp
Spare Tyre?
Guest rodneyp
Ok i took my spare tyre out the other day to fit my rear valance, and didnt have time to put it back. The interior of my car is fairly bare (no rear seats), and with a lack of spare tyre hovering behind the rear wheels, theres a noticeable difference in handling/driving. Would i be a fool if i left the spare tyre out? is it illegal? its just alot nicer with it not there! ed
cybernck
you'll find out when you get a puncture :P.
some people carry a can of tyreweld instead of a spare wheel.
Guest PacMan
I never carry a spare tyre unless i know one of my wheels is running on canvas. :P
Rob_the_Sparky
Tyre weld instead of spare is fine. Pretty certain they can't repair a tyre that is full of this stuff though but then how often do you get a puncture?
Rob
Guest saph
Most of the time they won't repair the tyre after a punture any way so you may as well use a can of tyre weld.
Simes
It's not illegal to have no spare, it is illegal however to have a bald spare tyre. :P
Guest hd_andy
Does that mean you can pass an MOT without the spare, but fail if it is bald?
nick
It is not illegal to carry a bald spare tyre.
Nick
Guest Wiggs
Both my 205's have pretty low tread on the spares, I know one is below the minimum, not failed an MOT though.
Guest timH
i've got a very bald spare - on the car.
come to think of it, it's got to be legal. - just illegal to fit it, and drive it on the road.
there's nothing to stop you carrying 10 bald spares if they'd fit in. - just can't fit them.
Edited by timH
Guest hd_andy
If you can carry a bald spare then it cant be a test point on the MOT, well I will find out on Saturday when mine goes for the MOT cos the spare is bald.
Guest Pete95
I'd certainly be interested to know, I only noticed recently that my stripped out 205TT has no spare wheel, and even the cage that holds the spare is gone!
MOT is the end of next month, so I need to know if I need to get hold of another wheel or not really.
Edited by Pete95
Guest hd_andy
I have just been looking it up on here MOTand it says:
c. presence and tightness of wheel fixing nuts, studs, bolts etc
Note: The condition of the spare wheel is not included in the inspection.  However, if a defect is seen, inform the vehicle presenter.
Note: Removal of wheel hub caps etc is not required.
Good news
Andy
Guest Pete95
Thats a bit unspecific, it doesnt say they dont check the spare tyre, just the wheel...
Wurzel
Definately make no difference if the spare is bald.
My other car failed for worn front tyre. I took it off in their car park and replaced it with the spare. Got the guy back out and he passed it.
As has been said, the spare can be bald and makes no difference, it's just illegal to fit it.
Pugnut
did you know that the new focus rs comes brand new with no spare wheel . instead they supply a can of tyreweld.
KRISKARRERA
Sadly tyreweld is pretty useless. My dad got a flat recently and had to use 2 cans of it and it still wasn't solid enough to drive after a few miles.
Guest rodneyp
check tightness off wheel bolts... uh oh! One of my rear wheels is only running on 3 tight bolts as the 4th wont tighten, screws in, but just keeps turning when it gets too tight. What am i gonna do to fix this? am i gonna need a whole new rear drum/hub? its on an XS, help! ed
nick
I watch all my mot's being done, and I've never seen one check the tightness of the w/bolts.
Nick
Guest rodneyp
lol ok, well i guess ill just have to save about £400 for MOT, then if nothing bad happens, i can spend it all on something nice :D like getting a new gearbox or something! or some twin 40s :P now thats an idea! :P
Guest Dino
Same with Ferraris.....
Guest dave364634
mot;
spare wheel/tyre not checked. however it must be held secure.
also if there is no spare, then (205 wise anyway), the spare wheel holder must be secure (cable tie will do) or removed.
Guest saph
Legaly you don't have to carry a spare its just common sense.
On an Mot they don't check the condition of the spare tyre however:
If you get pulled over by the police and they check your tyres including the spare and any of them are bald you can get up to 3 points per tyre.
The polices argument for this is if you get a punture and put the bald spare on, the car is then illegal.
Edited by saph
Guest turnip
thinking outloud...
cheapest and easiest way to raise the rear ride height by 5-10mm, remove spare, hmmmmm
thanks for the inspiration.
"If you get pulled over by the police and they check your tyres including the spare and any of them are bald you can get up to 3 points per tyre.
The polices argument for this is if you get a punture and put the bald spare on, the car is then illegal."
I'm sure this could be successfully argued against in court. Unless you are actually using it how can it be illegal?
Edited by turnip
