yeti-dj
Unlocking A Gti-6 Ecu
Probably the alarm is going off, but the siren is broken - seen a couple of 306 do that. Lock and unlock it, and chances are it'll be fine :ph34r:
[L'e$kro]
What about unlocking the ECU directly on the ECU itself?
Any clue on how to do this?
I guess we would need to remove the eeprom from the ECU board, then use a proper hardware reader/writer, with appropriate software?
I guess we could find cheap tools on ebay for this
Any clue about how to do it?
Regards,
Nicolas
[L'e$kro]
Hello
Anybody has any suggestions about this?
Where in the ECU is located the immobilizer code?
I cut off the eprom from a locked ECU, and will insert a socket instead. Do you think that if I load a gti-6 bin on a blank eprom it may be enough?
If you have any inputs about this, please let me know!
Nicolas
sub205
' date='Oct 6 2009, 03:18 PM' post='994552']
Hello
Nicolas
nope, the code is in an eeprom, small 8pinned device sitting somewhere (possible near the cpu) on the board.
you can also try to disassemble the rom and change the immo-check-routine with some NOPs. but thats more advanced stuff.
[L'e$kro]
Thanks for your reply
Tough, it would have been too easy then!
I'll try to locate this small eprom and check what standard is used
I've heard about a way to unlock the ECU without having the car, but can't find any infos on this. As people who have the knowledge and skills to do it often make money with it, very few infos are available, or I just do know what to look for perhaps... I wish there were as much interest as for videogame modchips :lol:
Nicolas
Edited by [L'e$kro]
