chris-gti
Gti-6 Head And S16 Block
chris-gti
I've tried the search function and can't find the answer I'm looking for so apologies if this has already been brought up.
Basically i have a 306 s16 lump which is going in my 205, I just wondered if the GTI-6 head would bolt straight onto the s16 block?
Thanks,
Chris
yup :D essentially the same block and crank, with different rods and pistons, you may end up with a slightly low compression ratio with the differing combustion chamber volumes and deck height-dish/dome volume of the pistons.
Edited by welshpug
chris-gti
Thanks for the fast reply, Would you say i'd be better off sticking to an s16 head then?
B1ack_Mi16
Putting the GTi6 head onto the S16 block will increase compression a little bit, approx from 10.4 -> 10.8.
About 3cc difference in chamer size.
chris-gti
Thanks for that, neither here nor there then on the grand scale of things. think i'll look for a gti-6 head to drop on.
