scumbag 0 Posted December 21, 2006 The local shop has got an electronic fault finder / reader with a list of fault codes. says you plug into diagnostic socket and it tells you if there are any problems. Would this work with an 88 1.9 gti and if so where is the diagnostic socket? Thanks in advance Share this post Link to post Share on other sites
welshpug 1,621 Posted December 21, 2006 nope, no diagnostic plug IIRC there weren't any diagnostic plugs till Motronic on the very late 205's you'll have the very simple Jetronic system on your car. Share this post Link to post Share on other sites
scumbag 0 Posted December 21, 2006 hmm would a different ecu make it faster? It doesnt seem as fast as it should be! Any tips? Next thing to do is lube blower motor again as squealing horribly, then the door hinge pins and the passenger lock. Then january is new dizzy, ht lead, plugs, oil change and cambelt. February is lowering time. 20 mm i reckon wicked Share this post Link to post Share on other sites
