t16ryan
205 Tu Xs
t16ryan
http://cgi.ebay.co.uk/CITROEN-AX-GT-205-1-...1QQcmdZViewItem
Anyone no much about these ? why does it need a better fuel pump ? also what should i expect to pay for a engine like this, looking for another TU for my G/Fs CJ as old XS lump getting tired ;) its has MG maestro carbs on it at the min which i will swap to the next engine,
stu_woac
you want to see recipts really we could all say thats done to are engines with out you knowing
plus it looks like its all just been painted to me
Edited by stu_woac
t16ryan
it has been painted, i asked him about reciepts he said he has them for the internals bearings rings ect, but not for the labour as the engine was bought from a tuning company, will it run ok with a standard pump? or best to fit a inline electric pump?
Jrod
Iron block? :P
Jer309GTi
Iron block? :P
My thoughts exactly. Maybe a 106 XSi or AX GTi block?
Sandy
It's an alloy block in the pictures.
Late 205 1.4's often had Iron blocks, all the UK 205 Rallyes did for example as well as the 106XSi 1.4 and AX GTi.
macaroni
You won't need an uprated fuel pump running a standard carb.
All that work and a standard carb and exhaust manifold?
stu_woac
stay clear
it is a alloy block not iron,
you wouldnt be running a engine with the money spent on it on a standard carb unless its being raced,, as it is not aloud to change inlets in some classes but most still change to the weber as its alowed
but why isnt the crank lighten and balance to go with the pistons and conrods???
I dont like it really so my advice is dont touch, your not even going to be able to here it running
t16ryan
Yeah fair comment anyone got a good running XS engine ? i would rather do the performance work myself so i no whats been done,
macaroni
Yes I have, but you can't have it!
Jrod
I have a spare but it's a bit far in Portsmouth!
t16ryan
think i may just rebuild the one that in there at the min :) thanks anyways
stu_woac
why do you rekon the engine is getting tierd mate??
t16ryan
just wants rings and stam seals ideally and headgasket on its way out ;) will do it over the winter :( i cant get all the performance bits cheap enoguh :)
