Rippthrough
Car Won't Idle - But Only When Its Warm?
Rippthrough
Anyone had a similar problem to save me replacing bits on a 'hope and see' basis. Basically, the car will idle fine when cold, but after a couple of minutes of driving, it suddenly won't idle, it drops to 500rpm, the lights dim and it cuts out. Give it another 5 minutes and it's back to working perfectly again?! :)
It's had a new temp sensor, checked and cleaned all the electrical connections, plugs and leads, lambda sensor diagnostics say everything is fine there. Any guesses? I was thinking maybe the coil pack, but it seems to run fine in the rest of the rev. range no matter what the temperature :ph34r:
hengti
maybe check that the cap on the AFM is sealed on - ?
Rippthrough
What AFM? :)
It's running monomotronic management.
hengti
sorry - i'm not familiar with your car ...
Rippthrough
Yeah, got me head scratching there :D
time to rip the lot out and finally install the MS I think.
Guest BrainFluid
Could there be a bad earth somewhere? Somewhere where when its getting warm its lowering the nessacery ammont of current need?
Just a thought.
Rippthrough
Just a thought.
Checked all the earths in the engine bay that I could find - what I can understand is it going back to running fine when it's fully warmed up!
rapide
My car had these symptoms a few months back. Turned out to be air leaks. Replaced the gasket on the manifold and it cured it completely
Rippthrough
Checked the gasket and re-torqued the manifold - still the same, my car has PFTE manifold/throttle body gaskets.
