ilovemypug
Tu 1.1 Bottom End With Tu3S Head And Carb
ilovemypug
As mentioned in the title, has anyone done this and if so any good? Have to keep the cc in the engine stock but want some more umpff.
Also thinking of going bike carb direction? Have to keep it all as low profile as possible and all mechanical, no electronics envolved ie itbs etc.
Any ideas, suggestions welcome.
Im about to resurrect an XR that needs some TLC as it has been parked for 5 years.
dawning
Heads are the same just the cam is different in the tu3s and the carb.
calvinhorse
I thought the ports were bigger
I'm sure the inlet Valves are bigger on the tu3s
Possibly different cc combustion chamber too
ilovemypug
See if Sandy comes along and shines us with his wisdom =)
ilovemypug
Bump
RossD
Very subtle differences on the TU3S ports compared to the more normal TU1 and TU3 heads. Cam is different, valve sizes are the same. Combustion chamber the same, hence compression is the same.
Identifiable from the '3S' cast into the top of the head itself.
Edited by RossD
calvinhorse
The inlet ports are a good 5-6mm bigger on the xs compared to the 1.1 I had a look yesterday, exhausts look very similar.
Does anybody know how to identify the xs cam? I've got what I believe is a 1.4 tu3 and a 1.4 tu3s cam
One is stamper 'A' the other stamped 'R'?
I've got a TU3S cam in the garage so I can check later this week if you don't find an answer in the meantime
calvinhorse
That would be ace Anthony, the stamp is on the fuel pump end, easy to spot
Sorry for the delay, but having finally had chance to dig it out and check, my TU3S cam is stamped "R" :)
calvinhorse
Brilliant, thanks Anthony much appreciated
ilovemypug
would there be any point in skipping the tu3s head and put euro rallye head? im in portugal from time to time they show up- Or a tu3j head off a 106 rallye? can get one for 60€
ilovemypug
right now there is a complete head (head, camshaft, rockers) for 250€
and a 106 rallye head for 60€
