GazMav
V6 Speed Sensor Pins
GazMav
Hi guys,
I have a 3 pin speed sensor on the V6 and can't find/work out which pin needs the 12v (or earth) adding. Currently have the 2 pin plug which i want to replace with the 3 pin plug.
The sensor is on the car and it was a struggle with the subframe off so don't really want to take it off to test on the bench if I can help it.
hopefully someone can remember :-)
BTW, I have removed the speed module that came off the 406 as I thought this was just for the cluster speedo.
Found this thread but doesn't detail the pins...
http://forum.205gtidrivers.com/index.php?showtopic=164039
Cheers all.
Gaz
wire 1360 from pin 9 of the ecu is the signal wire, other two need sensor earth and a 12v switched feed.
vss pins 1 12v switched, 2 sensor earth, 3 wire 1360 signal.
GazMav
Thanks Welshpug, much appreciated.
