GazMav
205 V6 Cooling Fan
GazMav
Hi All,
Just trying to wire up the cooling fan but the original 406 wire that triggers the fan relay has long gone along with the cooling fan module (don't even remember seeing that).
I have the coolant gauge wired up but not sure how I could use that signal to trigger the fan.
Was thinking of running the fan all the time as I have a 10 second delay relay so could wait 10 seconds after the engine start and have the fan run all the time.
Does anyone have any suggestions?
Thanks,
Gaz
use the 205 wiring, you dont want the fan on all the time.
406 wiring is very complex.
GazMav
Cheers, Should have thought of that, looks simple.
