timoth123
Ew10J4S Intake
timoth123
Guys,
Just about to get a manifold made up for some throttle bodies for this engine.
The standard intake has 2 oil breather connections on it, but lookig at the PDF of the jenvey it appears to not have them.
That mean they're not needed?? Surely they are?
catch tank !!!!
timoth123
Guys,
Sandy
You'd need to make another breather elsewhere, ie GTI138 rear cam cover has one, or if the engine's apart, put a brether into the block oil drain below where the inlet breathers are (which is what I do). Or make a provision in the manifold flange.
Edited by Sandy
timoth123
Ok, so just use a 138 rear cover and block off the breathers next to the inlet ports?
The engine isn't going to be apart so easy options for now.
Edited by timoth123
Schumi
Any photo for this application Sandy ?
