idoari
205 Gti 1.6 1992 Restoration :)
idoari
Hi,
let me intreduce myself my name is Ido i live in Israel and after 1.5 years of searching (i Israel the GTI is quite rare) i bought a 1.6 GTI.
the car is looks like well maintain (it has a strong engine and good gearbox) but doesn't have service history. so i decided to do a complete restoration ( both mechanicly and cosmeticly).
the main isue with this car is the electrics. the electrics is very very dodgy (a love of broken and missing wires). luck for me i'm a electronics engenneir ;)
123_Copy.jpg​
as far as i know, the 1.6 engines has two codes : B6E and B6D but i have B6J engine and i can't find and info on that model (maybe late model engine ?! )
the engine code is engraved on the block and the injectors and the dizzy is differenct as well.
IMG_1035_Copy.jpg​
the engine number plate is removed
IMG_1034_Copy.jpg​
tomorrow i will upload more pictures and tell you what i've done til now.
Ido
idoari
sorry about the delay...anyway this is how i got the car
10629827_10204838648545334_1270997481186​
1236376_10204838646465282_41797272707258​
the instrument cluster
10712847_10204838585903768_5136115184664​
IMG_0824_Copy.jpg​
in my way back home i noticed that all of the gauges in the dash (water temp, oil presure and temp) are not working and also the car stoll in the middle of the road twice and didn't want to start. after two minute i manage to start it. from that moment i knew that the first thing to fix it the dodgy electrics.
in the first day i remove all the stickers from the car and remove the ugly floor mats.
all the sunroof trim was LOADED with silicone and so is the handle (probebly becasue of a leak)
1458471_10205154926972097_27986120102662​
i hate that exhaust !! it WAY too loud , i will change it later on...
IMG_0841_Copy.jpg​
the engine when i got the car . first thing i saw is the aftermarket filter that sitting on top of the exhaust manifold - i will get rid of it later on and get the original filter box with the hoses.
10628124_10204838648265327_3924159751836​
the second thing i saw is the loom wire was rubbing on the plastic part that connect the throtle cable to the throttle body and stop it from closing all the way. the ideal was troable also ( the RPM keeps climbing up and down from 2K to 1K). i saw also that one of the wire of the throttle switch is broken (the middle one) and the two other is partly damaged. also i removed the wire that holds the battery in place and i will replaced it with a proper battery clamp.
i remove the paddels coves that came with the car, paint them and install the genuine rubber cover that i bought
10426546_10204838590503883_6958637033708​
10647036_10204838586583785_6171700851564​
i bought with the car a set of original 1.6 rims that is going back to the car.
10670036_10204838585983770_4862495902904​
here's what i've got with the car (they are 15" rims)
1_Copy.jpg​
i replace the steering wheel becuase the one that i have was way too worn ( i know it's grey steering wheel but i'll replace it to black one later on)
10629827_10204838589863867_3292821565811​
original gear know that i bought :)
10625131_10204838587143799_3551208908720​
i put back the original rear light units that i've had. the lens is broken on both sides so i've replace that to brand new on later.
10703715_10204838646385280_7579490008572​
in the meantime to pass the MOT i've had to have a working rear lights so i took them apart and clean all the contects.
before
10435002_10204838538982595_7382169635118​
before VS after
10153226_10204838539542609_3201409449399​
no , it's not a new rubber just a very clean one ;)
10639511_10204838538942594_9808128775764​
i restore the clock as well (it was very dim)
10372525_10204900329367316_3500801034255​
as you can see the sunroof trim was filled with silicone, the drain holes also
1800400_10204978386198688_12618148317574​
let the cleanning begin...
1920411_10204978386158687_54109056355929​
after the cleanning
10458709_10204978386678700_3677269486973​
look how much silicone was there
1969313_10204978386718701_76132204275495​
new spark plugs and recondition fuel injectors
1450725_10204978386838704_25059969285885​
10251900_10204978387438719_7789689442280​
i remove the fuse tray from the car to clean the cotects and to check if everything is good inside. also, i checked all the fuses and the relay - they was all OK.
1233423_10205089154647830_35702696077408​
a bit of cleanning
10698549_10205089155167843_3426940587249​
new rear 1/4" badges and two jets tank covers
10698705_10205113742822519_2976855490821​
10557280_10205113742862520_1087800844261​
the one that i had was broken
10689428_10205113742142502_4487015739365​
10153737_10205113742022499_2689697522953​
new genuine erling gasket kit
10593058_10205113743542537_2813127829741​
new fuel cap - the one that i've had was broken
10624723_10205113743662540_5908663379674​
i've started to fix all the electrics inside the car..
1780730_10205113742182503_48981292218329​
a new rear jet - i didnt' have one when i bought the car for some reason
10620612_10205113743702541_9356916750276​
idoari
new rear badges
1610814_10205141401833977_79801730989626​
the cable that connects to the sunroof lock was rusted and stuck so i decided to ovehaul the whole system.
10620823_10205141401793976_2262528954101​
fix the battery earth wire with solder and some heatshrink tubing to prevent oil and dirt coming in
1743516_10205142252895253_78918103693817​
i've rub down and painted the roof frame
10384652_10205147843555016_7799390945733​
10341829_10205147843635018_2724485012607​
cleaned the sunroof handle from the silicone
1898052_10205154840769942_66352907851329​
i saw that the vacuum advance of the distributor was disconnected from the engine vacuum so i've fix that as well
10647033_10205174871310693_7967750913825​
broken wire fixed
15774_10205174870350669_1609377863480530​
10615544_10205174871270692_3067290648183​
10644847_10205213993088713_6486634751855​
i've removed the whole engine loom to fix all the broken wires and clean all the connection properly
10687022_10205213993208716_2622285769512​
new sunroof handle seals
10616301_10205213993528724_3603662750440​
red trim
10665244_10205213993168715_8037247563088​
cleanning
10612959_10205224443829975_5962370867301​
clean with 95% alcohol
10712708_10205224443989979_8660545092507​
after
1610848_10205224443869976_47624414798850​
also, i've tested all the light bulbs to see if they're ok
10384685_10205224444789999_3675635030859​
new sunroof locking cable
10609438_10205236146602537_8023229264053​
new oil filler cap the one that i've had was broken as you can see
10556436_10205267148657569_6887577599797​
10477883_10205267147657544_1580996365204​
559602_10205267147617543_535270958824504​
the new cable fitted
10624607_10205267148697570_8120632205348​
brand new ignition amp :)
10352553_10205267148457564_2587942080501​
the engine sensors loom. i took apart all the wires from the connector , measure the distances that i need, solder new wires with heatshrink tubing.
10005969_10205335533967159_3931971980941​
a piece that my dad made to pull the new sunroof locking cable
10671307_10205335533887157_6979325270935​
1491380_10205335534007160_89934497909375​
the new engine loom finished. i will need just have to cover all the tubes with black tape but that's about it.
10470816_10205350223974400_8545033135550
enjoy ;)
Ido
Edited by idoari
allye
Absolutely brilliant, for me these are the most satisfying projects being completely de-chav'd and saved. Car is getting some love for the first time in a long time.
As above, good work :)
Good parts sourcing too :lol:
idoari
thanks guy it's not that easy so source the parts since all the parts i have to import from UK or other place in europe.
we don't have any new parts for 205 anymore in israel :\
2052NV
Wh ever owned that car before you needs to be banned from owning a car!!!!!
Brilliant work mate
acox99
Good work. Will be a really nice car when finished.
idoari
i wasn't updating for a while but things moving with the project...
i find out that one of the previous owners put a tinting stickers on the windows and the glue started to stink (probebly from sun exposure) so i've remove them with alcohol.
10670170_10204838590903893_3404053457451
i replace one of the vacuum hoses and the long vacuum hose that goes from the brake booster to the distributor was missing so i made one and put it there.
i've covered the whole engine loom that i fixed with tape to protect it from moisture and oil.
10613002_10205396028519485_6003595848941​
i've visit a scrap yard and got some goodies :)
1486157_10205390096411186_53254488093168​
complete dashboard
10338496_10205390127251957_4361257807322
scuttle panel with no brakes ( a little cleaning won't hurt :P )
1399143_10205390127291958_44999477735735​
sunvisors (one has the mirror missing)
10245364_10205390096451187_5246184900204
new complete steering columb trim
10679792_10205390095491163_6399810495260​
heater control
10827927_10205390095691168_6206267529756​
battery clamp (don't worry it will be painted)
10370812_10205390095451162_5930986156595
cleanning the scuttle ( there was a ton of mud and leaves inside and the side drains was completely clogged)
1974196_10205396029239503_21536011834185​
after cleanning
10750278_10205396028479484_6781597572532​
painting the battery clamp and the MAF bracket
10846163_10205396029799517_6319376364444
1797554_10205396030159526_31867844609561
battery clamp installed
10433937_10205430225294383_8442194075441
old vs new heater control i've cleaned the contacts and oil all the cogs
10501586_10205430227534439_7109942805168
heater fan old vs new (guess which is which :P )
i've cleaned the new one and oil it.
10835396_10205430227894448_8683794626568​
sunvisors installed
10854345_10205435385383382_8871481343578​
remove the back seats to see if the fuel pump wiring is OK and to extract the seat belt from underneath also to be able to remove the carpet for cleaning.
10714284_10205435386383407_5720003732462​
after cleaning and oil the seatbelts female sockets
10858454_10205435387023423_7649947715625
after removed the carpet
10848556_10205435387543436_2085610970853​
before vacuuming the carpet
10382560_10205435385623388_8738784747811​
after (not much of a difference but i will wash it tomorrow)
10411857_10205435385863394_1526420502035
enjoy ;)
Ido
idoari
just a little update i finished to wash the carpet today. i work on it for two hours with hot water, washing powder and hard brush. after a once over i've cleaned the remaining stains with dish soup and hot water and the result before you.
i think it came out beautifully.
10397073_10205442878730711_2882359700120​
Pugleyrich
Coming along nicely. That carpet looked heavily soiled in the back! Good work
idoari
in the past few weeks there was some progress...
i install the o-ring for the sunroof handle and check for leaks
10535036_10205458516441644_8054793789033​
i've had a fuel smell inside the car so i removed the rear seat to get access to the fuel pump, i've removed the pump and cleaned the bottom filter and fixed the wiring for the fuel pump and put hot melt glue on it to prevent moisture to get in,
10548123_10205458516921656_7278616242595​
i removed the seat belt retainers and the front seat rear mount and painted them black.
10845755_10205458518961707_2009840305683​
1531906_10205458544922356_66962598840056​
i cleaned the car with compress air
10298491_10205458518601698_7880569775684​
and installed the cleaned carpet back inside
1614164_10205477886925894_89076460334077​
installed the seat belt retainer back
10750512_10205477887005896_5091894962287​
i've went to the junk yard and get some goodies
10849762_10205496331306992_2609144056857​
10682216_10205496331747003_8186640868060​
overhaul the gear stick
10849914_10205496331867006_2930164321187​
905891_10205496332627025_704187545857668​
before state...
10750330_10205502132132009_8247153933513​
the gear stick that i got from the junk yard is form 205 TOP XRI and apparently it's different from the GTI one in both length and gear selector angle.
905547_10205502132292013_779092351011560​
the only reason that i wanted a new gear stick is because someone that got the car before me cut the head of the gear stick so i cant get the original gear knob on it. so in the end i went withthe GTI gear stick but i cut and weld the gear stick head on it (and painted it silver for rust protection)
10750510_10205516698976171_1897600960904​
i've painted the rusty bracket, cleaned the old grease ,put new one in and reattached the whole thing
10865909_10205516699016172_5468520250051​
now i can install the gear knob
10629480_10205516699056173_5484540377797​
i'v got some rear axle kit
10861129_10205502132052007_4227548547788​
installed the new ignition amp.
old vs new (in the bosch box)
10269328_10205564984663283_2086045936487​
put some thermal compound
10868021_10205564983943265_6266445490096​
and surround the whole thing with silicone to prevent dirt and moister to get in. i've also painted the braket that hold the amp black.
10872902_10205564983903264_7572407741484​
the engine keep stalling so i've remove the spark plugs and the two in the middle was dipped with oil.
10848683_10205516699776191_3139884023766​
i've cleaned the oil with fuel to remove the oil and use a wire brush to clean the electrodes.now the engine running much smoother but still not prefect.
got some oil and filters for the car just i need to replace the coolent to zerex one because i've heard prestone isn't good and i've got the wrong oil filter. the seller told me the 1109.AP is the same as the 1109.AL but it's not there is not valve inside.
10683666_10205564985023292_5135432447139​
Ido
idoari
ok a lot of updates....
i had a terrible water leak from the intake manifold so i've removed it.
10498476_10205662022969180_7186558287480​
i've cleaned the inside of the manifold with petrol and brush - it was very dirty inside as you can see.
10626339_10205662019769100_4861692366292​
i've cleaned the throtle body as well
10881639_10205662019689098_4655449067473​
i've cleaned and tested the alternator (since it didn't charge the battery) - now everything fine
10863822_10205662022009156_4236868244655​
the bolt that's responsible for the alternator belt tension was broken so i've replace it and paint the braket black
10644283_10205662021049132_8047954399229​
the new fuel filter
10805655_10205662023009181_8155845619076​
the manifold after cleanng and installing the new fuel injectors
1606323_10205662022289163_79705054332813​
the throtle body after cleaning
10917340_10205732107201242_5606323722209​
when i bought the car the heater matrix was disconnected
10891715_10205662019729099_6857664376375​
so i connected it and it was leaking so it will be replaced
10869724_10205676388128300_8827399326514​
new stuff - genuine oil filter , genuine coolent , new vacuum line , new coolent gauge sender and new fan switch
10872751_10205720851239850_4245694973085​
i've resoldered the broken wires for the fan switch and install it
10928185_10205874019748967_3863090107034​
i've cleaned the MAF sensor with this cleaner - just in case :D​
10419061_10205732107481249_4664041576244​
i've removed the fan blower transistor from the car and test the transistor and it was bad so i've replace it (i put themal grease under it and silicone around to prevent moisture to get under. also i've cleaned and solder the whole thing)
10904550_10205732110121315_2086734148867​
10918941_10205732109681304_6790608124781​
i've drained and filled the gearbox oil - this is the old stuff
10896380_10205748400968576_3588882572399​
fixed the front fog light - both of the wires was broken
10914783_10205764068040243_5727427106676​
i've got new rear axle nuts and covers and new sump plug
10750118_10205780095320915_1486690183274​
cleaned the seats
10931691_10205803458424978_3512570970083​
from the moment i've got the car - i saw that in the past the master cylinder was leaking and eat the paint
1475799_10205803462585082_30280665678370​
painted it...
10922332_10205803465065144_1523440384298​
the genuine air filter box and pipes
10887549_10205819134016858_7944946460110​
the air box was rusty so i've painted it
10928825_10205819134496870_6559167926794​
cleaned the old sponge from the back of the dashboard
10848843_10205845619638982_3981196226095​
and put a new one
10922384_10205845620238997_7123320199329​
new oil temp sensor
10900032_10205845619438977_1232213910712​
i've got the sunroof rubber seal and some vents
10818449_10205819135136886_1372164772101​
cleaned the SAD with carb cleaner
before...
10481866_10205851648149691_2130707336732​
after
10940579_10205851648189692_5216393347261​
10920933_10205851648589702_7027019822390​
i had a broken MAF gasket - so i made new one
10872977_10205851648629703_2171554827694​
it's made from special paper and i've put grease on it to help it seal.
10448693_10205851647389672_7619877095520​
the airbox and pipes installed
10931475_10205851649389722_5339873651473​
the old oil that was in the car - it was dirty and black
1669597_10205851647629678_26480124720349​
the sunroof seal installed
10841851_10205874020108976_4105200068353​
i've got interior light
10931313_10205874019668965_7327963215385​
new genuine air filter
10903886_10205874020188978_7735882367720
new coil
10408485_10205874020268980_8093830005083​
that's it for now
enjoy :)
Ido
Plumbob
Nice one! That car can hardly have worked at all when you got it! Keep it up!
Alan_M
Great work.
I must ask though, where are you getting the parts from as I guess a 205 GTi wasn't a popular car in Israel!
idoari
98% from them from EBay Uk or EBAY germany.
Slo
And people in the uk moan about parts prices lol nice work Ido love the passion
eddie bullit
Looks like you're doing a great job! Good luck with it. I'm looking forward to seeing the finished result!
idoari
If i was in the UK my car was a show car. everything is expensive to ship and you think twice before buying anything.
thanks 4 your support guys :)
updates coming up soon...
Ido
idoari
i didn't had time to update , now i have.
new heater matrix
10988296_10206018379197863_3775334522876​
new ECU temp sensor (genuine bosch)
10974584_10206018380837904_4767007005121​
new genuine thermostat (i ordered the wrong type the correct one on the way)
10900243_10206018381117911_7660614942637​
10959925_10206018380077885_6316695812604​
10981616_10206018380277890_2539424467401​
installing the heater matrix
10952951_10206054552342169_4978442225986​
new timing kit
10835094_10206054552582175_3989997855701​
new HT leads :) i got a good deal on them so i ordered them (they are the R-100 not the KV-85)
10974209_10206081640339352_1707860307853​
new gear linkage
10866090_10206081640379353_3328440557530​
instrument cluster i GREAT condition ( will be painted black to match my interior)
1557663_10206141958687273_66888214595622​
new exhaust fittings
10498052_10206141958727274_6239005130847​
new leather gaiter (the smell of new leather....I LOVE IT)
10854985_10206141959007281_1211041295543​
interior lamp and sunvisors installed (the lamp wiring loom was fixed also and tested)
11021334_10206175847454471_5890621970063​
painted the sunroof trim black ( i really need a new set the one in the middle is broken but glued)
1622430_10206175847414470_63740930670590​
new HT leads installed
11041860_10206183305360914_3539466189636​
look at the thickness comparison - massive differnce , the engine is running a lot smoother with this as well ;ׁ)
10887121_10206183305280912_9004770451012​
timing job
10847312_10206302489860452_8466524299525​
new water pump
10620501_10206302489220436_2028768337687​
before cleanning the water pump housing
11025312_10206302490300463_4084138732981​
after ( the white stuff is from the inside and it's not silicone so i left it alone)
11061993_10206302489180435_9217161806252​
new tensioner
1498844_10206302490180460_46216441537380​
ECU temp sensor installed
11082264_10206302489780450_8320148640342​
the thermostat that i ordered by mistake is for 205 TU engine and it's doesn't fit so i tested and install the old one until i get the correct one.
11053285_10206302490380465_7455154293569​
i painted the dashboard from grey to black with proper leather dye
10995812_10206365674320024_5421039964621​
the result (it came out fine by bit too shinny - i'm sure it will fade with the sun)
11080437_10206365674400026_2403996149014​
i got a washer tank that was missing from my car
11095616_10206365674360025_3266725857128â€
that's it for now
comment are welcome ;)
Ido
Plumbob
Nice work, well done.
Slo
Bit of a fail on the dashboard colouring there, all you need is some black satin aerosol and it will look original black perfect
idoari
i could do it with aerosol but aerosol will peal off over time and this dye won't.
remember that i needed to CHANGE my dash color from grey to black so i needed something to bond to the surface and not just lay on it.
Edited by idoari
Slo
it wont peel off if you wipe it down first remember this is inside not outside side where the elements are
idoari
maybe not all the elements , but the sun will do it. Israel is warm climate country.
