Paul_13
[Engine_Work] Puff The Magic Dervgon
Paul_13
I spy a bleeding turbo
I upsized the fuel filter, was a bitch to fit
My new conrods, from a hdi 306. Straight swap for 306 d turbo items.
Found the boost leak!
New one
Paul_13
Also fitted this: Manual boost controller. Helps with wastegate creep and you can control what boost the turbo runs.
I turned the fuel up a fair whack after this and its peaking at around 30 psi. Need to fit my ground LDA pin for more fuel on boost.
dcc
yay :)
Paul_13
Still need to strip that d turbo bottom end I got off you mate :lol:
Can't wait to get the TD04 on :)
madspikes
Where are the "no smoke no poke" pictures???
Great project.
Clive
Paul_13
Right update time...
Thanks again to Trent for the clocks/loom/dash surround!
I fitted these and every dial worked from the off so was happy with that, had to replace a s*it load of bulbs but thats a given with 205 clocks.
I was most chuffed about the rev counter working straight away, I know these can be a c*nt to get working.
All in all, it was pretty straight forward, i've taken the dashboard out in 205's enough times and had the whole thing back together and working in about 3 hours.
The stdt loom was like for like plug wise against the old NAD loom.
The "oh s*it my engine's already f***ed light"
I didn't have the coin tray or the other triangle trim so I decided to copy a mates idea and modify the cowling to accept a base model triangle trim.
I got it through a MOT earlier and went to costco to stock up on veg :)
Also centralised the rack and got the tracking sorted, should handle a bit better now.
Next on the list is:
Fit gti valance to be able to lower the rad further
Fit a slightly larger intercooler
Build up the engine with the td04
Get the exhaust built up
Sort out some uprated suspension
Paul_13
few pics of the td04 turbo ready to be clocked
allye
Loving this Paul, I really want to put a HDI in a 205 so bad!
Josh_Quant
nice upgrade on the clocks
you done well to get it all i give up in the end and fitted 309 clocks but no rev counter :mellow:
cheesegrater
Can I fit that tacho to mine just to watch it go off the gauge?
td_dan
Have you got a pic of the rev sensor connection please :) engine bay side also a pic of the wire colours thanks :)
Paul_13
Paul_13
Boom, boom.boom, let me here you say....
Josh_Quant
Whoops
vandal!
allye
Good effort son!
Your 205 killing skills are still going strong I see
GLPoomobile
This made me laugh, as we've been playing that song recently as it's going on the playlist for my son's first birthday party* :D Somehow we discovered months ago that he likes it.
"Geronimo, look out below, here comes the brother with the offbeat flow"
*Totally inappropriate for any child's party, but that just makes it funnier :ph34r:
Paul_13
New engine to go in is at the garage. Just waiting on a few hoses that the postman is taking the piss with
Paul_13
My new intercooler
Replacement rad, not cheap!
Paul_13
Bent this trying to get the clutch arm pin out.
Straightened out with a hammer and reused ;)
Paul_13
The engine ready to go in :)
new bits
Engine going in
Hanging on its mounts
Paul_13
Loads of room around the turbo
Paul_13
Air feed pipe in.
The coolant hose around the back of the engine was a complete bitch to get right. There's no room!
2052NV
Are you thinking the intercooler should stop it blowing up this time?
