How To Test A Fuel Pressure Regulator
It should be 3 Bar (tube disconnected) while the engine is running. It will slowly reduce back to zero once the engine is switched off, unless the pump has a non-return valve.
Stian_P
I did the test The same way welshpug did, so I cant have the engine running. Or is there a different way to test it?
yes, pressure gauge in the inlet pipe to the regulator and fire it up.
Stian_P
Should it read 3 bar at idle? What kind of threads do the fuelrail have?
Thanks for replying guys :-)
