Las
What Injection System And Engine Code/number
Las
I just found the little plate riveted to the block and it says D6C, but I see that you sometimes talk about Xu????. What does that number tell?
Also checked the ECU and it's a 125 2 row, and as far as I can tell (haynes book) it must be a Bosch Motronic ML4.1 system, am I correct?
Well the reason for asking is that I want to play a little with the fuel pressure, maybe raise it 0,2-0,4bar from stock. As you might have read in another topic I'm trying to find out where the horses went!
Jer309GTi
XU is the engine type, it will be followed by a 9 for a 1.9 'XU9' and then info about the number of valves per cylinder, 'XU9J4' being MI16, XU10 is a 2litre
KRISKARRERA
You need to do a whole load of basic system checks and even then if everything seems ok it might just be that the engine is tired and in need of a rebuild.
John
XU9J4 = D6C
early Mi16 88-89, no catalytic converter
1905cc
160hp @ 6500RPM
173Nm @ 5000RPM
XU9J4Z = DFW
later Mi16 89-92, cat version.
1905cc
150hp
174Nm @ 5000RPM
XU10J4Z = RFY
latest Mi16 92-96, cat
1998cc
155hp @ 6500 RPM
183 Nm at @ 3000rpm
XU10J4RS = RFS
306 GTI-6, cat
1998cc
167hp @ 6500 RPM
197Nm @ 5500 RPM
Edited by John
KRISKARRERA
Sorry to be pedantic but I just thought I'd add that for the UK the XU9J4 with D6C ran from July 1988 until (I think) October 1992 and had 181nm of torque. From 1991 they had a knock sensor.
And the XU10J4's torque peaked at 3500rpm.
