wardy18
2300cc 16v Build
B1ack_Mi16
i would have thought peak power will be lower down the rev range due to the amount of torque it will have with the bigger bore size so wont really have any need to rev it up to 8k
Depends on your cam choice I guess.
Mine has still climbing powercurve at the limiter at 8000rpm.
But if you are aiming for about 200-220bhp that should not be a problem to get below 7000rpm.
wardy18
with the right cam choice and head work, Matt has predicted approx 270bhp or higher so this is what im aiming for
my main restrictors will be the exhaust mani and the carbs i guess so once the engine is up and running all save up for TB's and a proper exhaust mani to match the engine spec
wardy18
thought i would update even thou not alot has happened, the GTi=6 engine is now sat at QEP with Matt and waiting for me to source the new 96mm crank and get that to him so he can pull the engine apart and measure up the new pistons that will be needed etc
progress is slow at the mo but also got alot to do to the car, ie widening my arches for the new wider wheels and making moulds to back myself up, adjusting the cars rides height for the new wheels anf giving the current engine a once over ready for next year
