kaich
Xu10head On A 1.9 8v?
DamirGTI
ditto! fit the gti6!!!!
Yes , it's better/newer engine then mi16 :) it is a bit pricey but worth the money for sure :blush:
Damir
kaich
Yes , it's better/newer engine then mi16 ;) it is a bit pricey but worth the money for sure B) Damir
of course mate! :) but as I have say above gti6 is my last resource :)anyway GTI6 engine is more powerful (and it have got more potential) and a I have read many thread about this engine....I think that is the most succesful engine for 205 upgrade ;) Cheers!
Sounds like a plan! Sorry for intruding on your thread btw Kaitch!
doesn't matter mate ;)
kaich
ahh. in taht case, get an Mi16 or a GTi-6. the XU7 has great tuning potential, but without a decent budget not a lot is going to happen. Hence why mine is still so ruddy slow!
OT but XU7 it's the engine wich derive the 206 rc engine, right?
Sandy
Boost? Idiots ;)
The 206 WRC engine is based on the XU7, but I expect only the block is retained in reality.
danpug
Boost? Idiots :P
:):P
eu_andreiutz
OT: does a xu9j4 16v (d6c) head fit on a xu9ja 8v (d6b) engine?
Sorry for the intrusion and thanks for the help.
NNN
Yes, both the xu9j4 and xu10j4 (and xu10j4r and rs) can be fit on a xu9 block... both conversions are as simple and as difficult as each other. You dont need any adaptor plates and the only 2 things that need some kind of attention are the top mount and the tensioner. The mount to be used, as Ive heard, should be the one from a 1.8 16v engine, but I cannot confirm that.
Both conversions have been done here in Argentina quite a few times, and none has been found to be easier.
Ive also read somewhere that the xu9j4 head slightly outflows the xu10j4 (the mi16 - S16 head, not the GTI6), can anyone with flowbench exp confirm that, since I thought that both head having the same valve size and port geometry (as far as my eyes can see) would flow similarely. Thanks.
eu_andreiutz
Ok, so should I change the electronics too? Or can I keep the Le2 jetronic I have now? What other modifications should I do?
Sorry for intruding here Kaich.
markw
so would an s16 head fit straight onto an alloy mi block(hope so as i just bought one)
