Edp
[car_restoration] My Sorrento Rebuild
Edp
I had a look earlier for you but theres none on there at the moment.
Keep an eye out though mine were about £25.
monkee87
I think i've found some! Bit steep though... You pay for what you want though. :blush:
de Noir
Edited by MH_
Dazza
Absolutely fantastic dedication there mate.
Oh and the cars not bad either .....
lukesaddy
absoluely lush mate, 100 out of 10 for dedication.
i hope my miami 1.9 will be as nice as this when its done :)
Guest rob_s
mint!
and luke fancy seeing you here lol!,after a 205 now? same sick of 106's now
lukesaddy
rob, are you rob with the tango / green 106 ?
have you got a 205 now too ?
Edp
cheers lads!
Para
Edp your project is very inspirational for me, as I'm about to do a GTI6 conversion on my GTI. Could you please tell me where did you bought the smaller engine mount ? I haven't seen any information about you changing the exhaust manifold ? Did you tilt the engine then ?
Also if you could help me with finding place to get those steel fuel lines going from fuel filter and also all the brake lines which are visible under the bonnet that would be great help.
Cheers,
Mike
Edited by Para
Edp
The smaller mount was from burton motorsport and its a mk 2 escort item. I cut and welded the exhaust flange to suit the Ashley exhaust/manifold and also added the lambda boss.
Th braided fuel lines were from a place in isleworth in england called thinkautomotive.
HTH
Edp
Mike you will need to measure the diameter of the pipes of the picture you sent me. You need the internal diameter.
I cannot find the paperwork and do not remember the size. Sorry!
Edp
Well I'm starting all this again.
Going back to 8v power. IMO the GTi6 lump is far far too heavy for the nimble 205 chassis and so have decided to reinstate a 1900 lump. Keep a look out in the for sale section as this engine and plenty of other bits will be up for grabs.
I will of course carry on taking photos on the 'new' journey and hopefully getting plenty of feedback from you guys!
Wish me luck!
maxi
Ed, I have the "right" 16v engine sat here in the garage, full setup! If you fancy it give me a shout.....
Hope all is good your end mate.
Maxi
Edp
Update: Mi16 engine bought from Maxi, stripped and re-built. Dropped in and now I have this back on the road :)
Alastairh
Perfect. Well done, it looks stunning.
As Alastair says... looks absolutely spot on!
