Jrod
Clutch Upgrade?
Jrod
Right my clutch is now on it's way out and slips badly.
I can change it myself easily as I've done 2 gearbox changes and that only took me 2 hours last time.
The thing is I don't want just to swap for another cheapy 180mm clutch as I'm hoping to get a decent amount of power out of the car.
Stu told me you can put a saxo 200mm clutch on but I just wondered if this fits straight on?
Will I need the VTR or VTS kit? I'm assuming all the bits would be the same/fit without butchering (thrust bearing, clutch cover?)
TU3S btw
Edited by Jrod
j_turnell
I would imagine you buy a saxo flywheel and clutch kit and bolt it all on. Make sure you use thredlock on the flywheel bolts ;)
Rippthrough
I think you can just get your original flywheel machined out to take a 200mm clutch, I think the 180mm flywheels are lighter too so that's a bonus.
-Phillip
christopher
-Phillip
I seem to remember that the TU3 flywheel weighs in at 3.9 kg's where a fully lightened TU5 one is about 4.5 kgs
Sandy has machined TU3 flywheels to use a 200mm clutch.
I'm planning to use a TU3 flywheel with a 180mm Helix cutch. The pedal pressure is supposed to be almost the same and the rating far over what I will need (171Nm 126lb Ft)
Jrod
I think I'm just going to stick with a 180mm for the time being. I have a spare engine and will keep the flywheel to get that lightened balanced + ready to take a 200mm clutch.
Edited by Jrod
Jrod
Right just wondered if anyone can tell me if a 106 1.3 rallye rallye clutch will fit? (their are some listed as 1.3 rallye and ax gt so I assume the rallye lcutch fits the TU3S?
Edited by Jrod
