Jrod
Tu3s Gearbox Change
Jrod
Well as the Ma box is crap mine started grinding and crunching when chaging gears.
I've got a new box off an ax gt and have swapped it.
Just need to fill it with oil... is the little black cap on the top where the oil goes in?
2 litres?
Ta.
Jrod
Was hoping for a slightly quicker reply...
I can't test this new box 'til I get some oil in it. :)
calvinhorse
yes and yes
Jrod
Done and done!
Feels weird to drive without having to force gears and lots of crunching.
Also feels weird becuase the clutchbite point is in a different place!
Jrod
Grrrrrrrr it's deffo not an XS gearbox and is a normal one.
MartinM
To your original question...strictly speaking...
...no and yes
There is a specific filler plug - IIRC above and left of the drain plug
You fill it up through that hole with the car level until it starts coming back out at you
For a completely empty gearbox that should be 2 litres, but if you just stick 2 litres in through the breather (the black plug you mention) then you could be overfilling.
Remember it's the 75/80W oil you need - not that common to get hold of (Halfords do it)
stu_woac
what have you done with the old box??
also martin is right you really should not fill through the breather but its a way of doing it but not the quickest or the right way
how can you tell its not a xs/ax gt box you should be at 18mph at 1000 revs in 5th if it is or 21 if not
Jrod
I have the old box but I let it run dry on oil B)
before 70mph was 4000ish revs, now it's 3000, That works out about right to your speeds.
The new box was completly empty and I put 2 litres down that hole, don't know where the drain or filler plugs are on the side but i will take a photo and maybe someone can pointthem out to me ready for when I swap the box AGAIN for an XS one
I used the right oil :blush:
Took me 4 hours in total and that was my first ever try so I was pleased.
stu_woac
take the passage wheel of and you should see two plugs with a 8mm square holes in, one on the bottom of the diff (drain) and one is on the front of the box
that sounds like a 205 rallye box stupidly long
p.s. a box change for me is 45mins B)
and a engine and gearbox is 4 hrs
I must stop braking my xs's lol
Edited by stu_woac
Jrod
What do you use to undo those square plugs :)
I recon I can do it in 2 hours next time.
stu_woac
a sump plug tool its called and you want a 8mm which also works for the sump to :)
Jrod
Nice one, cheers for all the info.
trogboy
You want one of these fellas.
As stu says good for the sump plug and filler/drain holes on the gearbox. Plus they are also good for tensioning up the cambelt as they fit the square hole in the tensioner pully.
Ad
Guest sam-black
Ad
Or one way I have found when I haven't had the right tool is the square bar in the middle of a door handle mechanism :) , is just the right size and works a treat to. Bit of useless information but still thought i might aswell share it with you.
Sam.
