mmt 14 Posted September 29, 2017 Hi guys, What is considered to be the Best gear Oil with a plate diff installed? Race only. Which Oil do you guys use ? Share this post Link to post Share on other sites
welshpug 1,621 Posted September 29, 2017 standard synchro gearset and you need to use normal 75w80, you can add some redline friction modifier to quieten the plates down, ensure it is not EP type oil. Total have supplied the BV oils to PSA for years, it has been changed recently to a straight 75w formula which is backwards compatible with all BE and MA boxes. if its a dog gearset then go with whatever the diff manufacturer recommends, this tends to be very incompatible with peugeot synchros. Share this post Link to post Share on other sites
mmt 14 Posted September 29, 2017 Thanks. Not too worried about plate noise:-) Would a Castrol Syntrans V FE 75W-80 be suitable? http://www.opieoils.co.uk/p-92422-castrol-syntrans-v-fe-75w-80-manual-transmission-fluid.aspx Or Would a Castrol Axle Z Limited Slip 90 be better? https://m.ebay.co.uk/itm/Castrol-Axle-Z-Limited-Slip-90-was-Hypoy-LS90-1-LITRE-1L-/161174862032 Or???? Share this post Link to post Share on other sites
welshpug 1,621 Posted September 29, 2017 go to your local motorfactor or dealer, get 75w80, will be far cheaper. Share this post Link to post Share on other sites
petert 549 Posted September 30, 2017 I've been using Penrite Pro Gear 75W-90 for a while now. It already has some friction modifier built in and seems to play nice with the synchros. I found that Castrol Syntrax was definitely not compatible with BE1/BE3 synchros. Share this post Link to post Share on other sites
mmt 14 Posted September 30, 2017 Any Castrol reccommedations? Share this post Link to post Share on other sites
wicked 103 3 Cars Posted September 30, 2017 The syntrax is full synthetic; afaik you should avoid full synthetic. Share this post Link to post Share on other sites
welshpug 1,621 Posted September 30, 2017 if they do a standard 75w80 then yes... Share this post Link to post Share on other sites
welshpug 1,621 Posted September 30, 2017 The syntrax is full synthetic; afaik you should avoid full synthetic. you may be right with that, the comma 75w80 i picked up yesterday for a be4 box in a 407 is mineral to gl4 spec. Share this post Link to post Share on other sites
mmt 14 Posted September 30, 2017 Thanks Guys. I have been surfing a bit tonight. Anyone know this Oil from Millers: http://www.millersoils.co.uk/pdf/datasheets/CRX-LS-75w90-NT+.pdf Share this post Link to post Share on other sites
