Thijs_Rallye
Oil Pump Xu9
Thijs_Rallye
Hi,
Does anyone know if the oil pump halves are matched pairs? Or can I just swap them around?
I will have to extend the pickup on my pump and it would be much more handy to extend one of the pickups I have lying around and then swap it over to my pump. Since I don't have a lift available at home I'll have to do it elsewhere where I can't let the car on the lift until the extension is done.
Cheers,
Thijs
B1ack_Mi16
I would say they're not matched, so you can just get one modified and swap it when done.
But might be different between different type of pumps, i.e. XU10J4TE/XUD11 pump has larger internal gears than the regular 1.9/2.0 16v pumps etc.
you can pull the whole pump out fine, bit fiddly but possible.
colti
I recently made up a good pump from a number of units,admittedly on an xu10 motor.So no they're not matched.
