selfyyy
Rear Beam Mounts
selfyyy
Has anyone got the dimensions for the rear beam mounts, want to have some made but removing the beam to measure them makes the care immobile.
Ø50 x 50 long.
dcc
Which mounts
Posted (edited)
I've made a few sets and you really need to know what you're doing, in order to get the tolerances correct. Additionally, the front bushes in your pic aren't very good as they don't have a crush tube. Without they'll flog out prematurely. You'll never get the front bushes out without damaging them. As I said earlier, the rear blocks are easy. Just drill a Ø10.5mm hole through some Ø50 bar. The original blocks are offset but that's unnecessary.
I think I used Sustamid for the front bushes.
Edited by petert
I've made upteen sets. If you can use a lathe you can make these, there is nothing complicated about them. I use Acetal usually.
