flyfisher
Drop Link Problem
flyfisher
Hi got a problem just replacing the osf jdrop link on my 205 cti problem is on full lock the bolt head that holds lower hub to strut hits the drop link bar but only on full lock any one else had this problem many thanks
Is this with the car jacked up and no weight on the wheel?
As it's quite common like this, but with the car on its wheels it should not foul.
flyfisher
Ok thanks
have you got the bolt in the right way? adding a washer between the droplink and the tab may help, also make sure the damper leg is located correctly.
but as Tom said, they are bloomin close anyway.
flyfisher
Yes bolts the same as other side I think when I checked it it was jacked up may be with weight on f/wheels it will miss ?
toolie72
I had this and put it down to shocks having the plate in the wrong place-it was the only difference
Anyway, I used a fat washer to space it back slightly
Then for piece of mind I put white insulating tape on the drop link where I thought it might touch
Ran her about and tape was unmarked-so in road running it was missing (but must be just a bahair in it)
