jdr
Rallye Starting Issue
jdr
Thanks for all the help, sorry for the delay the car is kept in another location and only get to work on it once a month.
I will try all the connections as you say, however I forgot about this extra wire from the coil pack, its not one of the four that goes into to the coil. Can anyone tell me what it does?
It looks like a ground as the plastic box it connects to is bolted on. The wire has snapped off the plastic box and there isn't enough metal left on the box to solder back on.
Can I buy the plastic box anywhere? Like is it a fuse or similar?
jdr
Thanks for the help all, the rallye is finally back up an running! Was the ignition coil in the end.
