Telf
Hi all,
After a bit of advice please
The block I had vapour cleaned has been sitting for quite a while now. Prior to starting a build I figure I should make sure theres no cleaning substrate left in it. Should I therefore remove the 2 items Ive arrowed in the picture to make sure its all clean? I suspect there may be crap built up behind them.
Undo the plugs at either end with the appropriate size allen key. Wash out the channel with high pressure water and reseal with Loctite 569 (or similar thread sealant). There's no need to remove the welsh plugs. You can clean behind them easily.
Telf
Thanks peter
Barryboy85
Telf did you treat the block with anything after getting it vapour blasted?
Telf
I haven't no
Barryboy85
I'm not sure if you should or not?
Telf
I don't know either tbh. Anybody have any advice please?
Barryboy85
I'm sure I've read that it should be sealed once done to stop it from furring up.
Telf
some headway this week. The engine from the car is now out and has taken up residence in my mates garage:
Telf
The plan is to separate the gearbox and clean it and then remove all the ancillaries, pipes etc and clean them up to. Everything will then be donated to the new block
Telf
1 X gearbox degreased and partially cleaned
MrAndy
Does anybody have the XU9 8v rebuild manual available? I have the 16v engine manual, but would like to have the 8v also.
Thx,
-A-
hoodygoodwood
That's good value for a set of 4 liners , 4 sets of rings and the pistons as well but I don't know anything about the make and if they are any good . I bought Kobelschmidt liners for my last 2 engine rebuilds and they seemed to be excellent quality .
I couldn't afford vapour blasting for my block and castings so I used wire brush heads in a cordless drill to remove corrosion and scale inside and out , to clean the dust out once finished I suspended the block from the rafters of my garage over a drip tray , removed the plugs each end of the oil gallery ( with the allen key fixing ) and flushed it out with new white spirit . I bought a selection of wire handled test tube brushes off Ebay and used them to get into the oil ways , with a bit of effort the block is literally spotless inside and out .I brush painted it with black engine enamel and would definitely paint yours as it will go white and powdery quite quickly once the damp gets to it .
DamirGTI
I've also noticed that pug1Off do a complete kit for £450 .
Not really sure the best way to go
https://peugeot-tuning-parts.co.uk/205-rebuild-restoration-peugeot-1-9-gti-engine.html
The price of the liners dropped quite a bit , at least over here dunno about UK , one liner cost app. 20 quid from where I'm buying and It's Goetze brand which is best OE spec .
D
