acox99
barneys66
Sent it back to the workshop for the winter.
List of things to do; new block, sort starting issue, new drivers' window reg (thanks to jackherer) and drivers' upper door hinge replacement. Easy...
took the dashboard out, exctacted the wiring looms and removed the alarm, granted it was all soldered and intact but thin gauge wires tapped into large power wires and wrapped in tape, URGH!!!
then removed the front lighting loom and fusebox and the heater box to access the sound deadening sheet on the bulkhead.
very little left of it now but still rolling and just about watertight
dannydub
Got the car back out the garage and took it to work and left it in the corner of the workshop.
Been spending my lunch breaks removing and inspecting the breather hoses as I have an idle issue.
Ordered some new hoses from Stew at Baker BM which should be here tomorrow.
Gonna spend my lunch breaks this week refitting the hoses and fingers crossed should help sort the idle issue out. (Only taken 12 years of ownership to get round to sorting this!)
pp205
Replaced my rear windscreen wiper motor as it had worked intermittently for about the last 8 years. Works nicely now. Thought about washing the car, didn't wash it and went inside for a nap.
Gaz205
Update us as you how you get on with the hoses
woodymi16
Stripped the MI that I broke back in May. That's a piston and rod shredded to bits.
woodymi16
On the track?
Yes it was going really well until it let go
AlexRS2782
Renewed the insurance for another year :)
calvinhorse
New centre exhaust section
3x new wipers
Oil + filter
New exhaust rubbers
New exhaust gasket
Overhauled front brakes
Checked lights, horn, brake pipes, topped up fluids
It's amazing how a car comes to life again after being off the road for a few years, it's a great feeling! MOT tomorrow
3x new wipers
Oil + filter
New exhaust rubbers
New exhaust gasket
Which car is this Cal??
calvinhorse
I bought a 205 style a while back off a mate, it's lowered on Rallye rims, it originally came off a little old lady in Buxton post office, it was mega tidy and not messed with but it's stood outside for a few years and ended up covered in dents, solid tho and 80k on the clock
calvinhorse
That's literally the only pick I have :D
calvinhorse
Failed mot because one of the rear fog lights didn't work...
It's a phase 1.5 :D
BERTMAN
MIG'd up a frame for the boot and mounted my 1.9 shell onto this little geoffrey...
...not welded in a few years so i was bricking it when I let it take the weight :lol:.
It's a phase 1.5 :D
what a noob! guy doesn't know his manual!
dannydub
Hoses all connected up and new seals round the injectors and the car sounds totally different and idles perfectly! Literally cant believe thats all it was!
Only snag is the inlet manifold gasket is leaking coolant. Any suggestions on how to rectify this?
barneys66
Radweld!
dcc
Radweld!
god no! haha
take the inlet off, but drain the coolant first - else it will quickly make it's way down the inlet ports!
you can either tap and fit a grub screw to the 2 holes, or a dab of sealant in them (the later more of a bodge though!)
generally a new inlet gasket is required when you take the inlet off - Peugeot items actually come with a little bit of a soft rubber already applied around the port shape. a non genuine item will benefit from a good smear of grease to help it seal (not something everyone will agree with, but I've always done it after being recommended to do it with the paper/fiber gaskets :) )
dannydub
I had to use an aftermarket gasket as my local Peugeot dealer no longer lists them.
Would you smear both sides of the gasket with grease?
What bolts would you use to fill the hole? Dont the heads hit on the inlet manifold?
dannydub
Ahh just googled what you meant. Basically just wind a thread in the tapped holes
dcc
yep!
I am pretty sure TAG has photos of when he repaired his,
dannydub
yep!
Do you know what length grub screw to use?
Doesn't need to be very long - think I used an M8 x 10mm grub screw to do mine, after drilling and tapping the hole obviously.
calvinhorse
Passed its MOT!!!!!
