timoth123
[Car_Restoration] 1.9 Restoration
timoth123
Hi,
I've been lurking on the forum for a little while now, stealing information from other peoples posts.
And thought it about time I shared my project.
I've always dreamed of owning a gleaming Gti in as factory condition as possible. Knowing that I was never going to be happy with one that was already available, and wanting a project. I decided to get an as complete as possible starter with as little chassis and bosywork as possible for a 20 yr old car.
It didn't take too long before I found a suitable candidate. A 1988 1.9 in silver.
59506292c567efcbd2948676cd9d26a4_zpsc1dd
3ce0fb29b4f80da26930e1df92eeb675_zps6416
40c66b0ad68474bb5084cf47140b07d2_zps5bee
After a few question answered by the seller I was on route with a trailer to see what it was like. It was pretty rough, it didn't run too well, was missing a few little bits like grill and intake hose. And had the most ridiculous exhaust that could easily fit my size 12s in!
8a535eb5d68e7ca6f714e039c1720fb8_zpsfcd4
But everything else seemed complete and unbroken. And the chassis seemed solid enough excluding the usual bubbling on the sill next to the rear arches and bottom of the footwell. So I parted with not too much money and took it home.
I got stuck into stripping it straight away I started with the outside.
f1cbdc6a5ac8896bd46fd9f6d796a50f_zps4122
c7dcc32ecf42df5a02a8ad9eb1639fcf_zpsda6e
I had concerns straight away with the amount of corrosion around the headlight panel, how did I miss that?
But I pressed on and started to strip the inside.
db93e80f130bcb1d2faf10a8eacacdd9_zps297d
And then found the nightmare looking inside the rear quarters at the arches. It's obviously been in an accident on both sides, and repaired to a pretty poor standard. Both inner arches, the top of the sill and quarters were all badly corroded.
b9b3044cb07b5297b927260bb5bbe98b_zps3d9a
8b870ae63fe02937c856643072bc93f5_zps03ca
I'm amateur at best with welding, and this was way out of my league to sort out to a standard I am going to be happy with. I had no choice but to call in the professionals to see what it would cost to sort, I had 3 quotes, the lowest being £3500 just for the welding work. I nearly passed out. I felt like such an idiot for not spotting it when I looked at the car originally.
That left only one option to me, to re shell the car.
The criteria was simple, the new shell had to be solid with no rust, a phase 1.5 original 1.9. After a fair bit of looking, Matt from Pug1off came to the rescue with a 1990 graphite grey that was already stripped and for a bargain price. Phew!
Edited by timoth123
timoth123
I carried on stripping the original shell of every remaining nut, bolt and clip ready to replace or refurb.
f138d889a5ed664c42510c0425c7ace1_zpsd520
Then got stuck into the new shell, but first I wanted a spit for the car to make working on the underside easier.
I made up a couple of A frames with rotating brackets!
f36eaef286fbf1647347222f682589df_zpsda71
Made up some brackets to weld to the rotating part of the frame. I was quite impressed with how it turned out!
31fa9ebd988feb69bb45e1431933803e_zpsfb21
57cdf4a7acd3ec00ccc4ee1371c983de_zps1664
The drivers side rear bumper mount was wrecked, so cut the good one out of the original shell and welded it into the new shell.
c00b5b70d69203f1860e206dec3504da_zpsa944
At this point I started looking for a decent bodyshop. I wanted the whole car bare metalled so that there would be no nasties hiding under fresh new paint work. In hindsight, I should have had the car dipped or soda blasted then primed, then pass it on to the body shop. But they were happy to do it and I'm happy that they did a good job. A few weeks into them having it I took a trip upto the shop to check it out.
What a difference...
e83abeeaeb6a6855021165a526c6c9ca_zpsbe0f
d55f3966df50622e356a4871d23d043a_zps81b2
While the shell was in the bodyshop I set about refurbing the rear beam. Replacing all the bearing, seals and shafts. Then gave it some colour and a solid mount kit. Aswell as some new blistein dampers not seen here.
7a6d32eb5754a3a34c08b56f01e8487a_zps2784
Then a week before I had to go tot the Falklands for 4 months I got the call the shell was completed
Good god they had done an unbelievable job, it was hard to believe it was the same car. The colour really does pop, it's standard graphite grey, but I'm sure it wouldn't have looked this good from factory!!
3f8dc07f45503c277fa6afbd8ecced00_zpsecf1
21b7350bd89093428c5a9705e2f86762_zps0411
I've now returned back to the uk and can't wait to get started on rebuilding her in the new year!!
allye
Amazing work! Great colour too. Look forward to your updates.
eddie bullit
Stunning! Looks like you're doing an amazing job..can't wait for an update on this
nick205
Ditto to the above, great effort and I have to say I really like the colour as well. White or red are generally my preference, but a fresh grey like that looks really good.
Just embarking on the same project, but starting with a complete (but rotten) car and a 2nd better condition bare shell to prepare, then rebuild with the parts from the complete car.
Keep the photos coming as you'll help keep me motivated :D​
can;' believe you scrapped it for just sills, I'm working on one far worse, needs a front floor rear section and both front inner wings bits of boot floor etc!
could have cut that lot from your mint shell before scrapping it!
Its interesting to see the trend with projects very much changing, only a few years all new projects would begin with folk ripping the trim out into a skip and fitting a roll cage, but now there are some very nice restoration works underway.
The shell looks great in its new paint, look forward to see the rest unfold.
allye
Very true tom, even in my time track cars and gti6's have slowed right down and spits seem to be the new trend to scrub your bottom!
DamirGTI
Ditto :blink: ... looked like sound bodywork bar the rear sill segments (kinda common rust spots anyway.. and usually isn't as bad as it looks that's what frighten you off by the looks) , i'd fix that one for sure if i where you ...
Might understand the reason being you're not as handy with the welding as you've said , but could at least try/took the opportunity with that one and practice/learn welding as you go along with the project , gaining the welding skills and fixing up the car by yourself (and that really is , an magic feeling !) .
D
timoth123
Yeh I've no doubt I could have repaired it my self. But, and this is what really matters to me here, not to a professional/ factory standard. If it was for track or just to get it going again I would of been happy to give it ago.
The pics really don't show how bad it was. Once I'd got the gearbox/battery box out, all under there was shot too. Plus headlight panels, front inner wings weren't that great. Aswell as the boot floor and under the tank.
It's my fault, I shouldn't have been so eager in the first place to get one and looked the original shell over a little better.
You live and learn!
will1991
Looking very thorough. Top job.
Looks as if you get a nice factory fit sunroof with your new shell too?
johniban
that is an awesome colour!
arnold80
cracking paint job! hope my graphite comes out looking as good!
timoth123
Bit of a short update.
Well I returned back to Peterborough and thought I'd get stuck into her straight away. My first job was to check everything was ok for the 5 months I've been away from her.
And shock horror, someone has decided that the best place to store some glass panes and a set of scabby wheels was up against my nice newly painted tailgate. Rather than propping it up against it with some clothes to protect it, it looks like they've just let it fall onto it, scratching right through to the primer in several locations, not to mention the scuffs from the wheels!! Brilliant!
So off that went back to the bodyshop yesterday, as if the 3k price tag wasn't high enough to start with, add another couple hundred to have that redone. Grrrrrr!
So the first job I got on with was starting to strip the engine, I really need to get the head sent away to be refurbed.
Started stripping off the ancillaries and other bits,
Found some lovely looking stuff behind the thermostat!
c8728442a278359939f6535bbfa82028_zps6a17
Then could I hell get the crank pulley bolt off, I had to stop myself in the end as I was convinced something would break. I've ordered a proper flywheel locking tool which should be here on Monday, and an updated windy gun!
So this is as far as I got! Nowhere near as far along as I wanted to be by the end of the week.
6ec63bed31e1fac74fb3ad75623c6cff_zps4679
I also got the shell out of storage and back in the workshop and on the spit ready to put hoses back on the underside.
Also put new rivnuts in the roof for the sunroof.
Slipped my mind to get photos of that though!
And that's it for the time being, hopefully I'll get abit more done this weekend!!
(It WILL be completed by the summer, I hope)
m@ttc
whats that stuff behind the thermostat? great project btw.
timoth123
Small update!
I'm still waiting for the flywheel locking tool to turn up, so the engine hasn't been touched unfortunately!
Fitted the rear beam with new wheel bearings/hubs and bolted it to the car, fitted the old discs and the original wheels. I did this to aid in moving it around. It kind of reminds me of a wheel borrow now! A very expensive one!!
75a2ac68b66c753dd91ac9da2c0bcb4f_zpsf18b
138425ceb0451b10de463af4db44368c_zpsee71
948c9175bb1a8f510a3e8311fd5caadb_zps70c3
3a19ef6628ad55a586a8b27bd95a77b5_zps59f1
I'm not convinced on that ride height though. I wanted standard height! :(
Quick pic of the sunroof rivets in place. Refurbed sunroof frame is now also in place and started to rebuild the doors and ancillaries!
14bc94ea2007121b273dcdec105826fc_zps1137
And that's about it, other than I've posted about 20 kg of nuts bolts and brackets to be powder coated or zinc plated. So hopefully have those soon!!
mhdurrani
Just read through all this one.word WOW, I love it given me sooooo much inspiration as to how I want mine to go, think I will check over it again on day of collection, to.be on the safe side good job me.mate is coming with me who.is a welder and body repair as a living so all covered for especially with mates rates ;-) this thread has shown.me to do mine to the same standard though I hope I can save the original shell any can be saved depends how much you want to spend I guess,
Look forward to seeing more updates.
To get pulley bolt undone, take sump off wedge a lump of timber between crank web and block then undo the bolt.
mrfirepro
Great work Tim,
I think your ahead of me for a while, will try and catch up..
Paintwork is peachy......
Small problem looking at this picture;
http://i751.photobucket.com/albums/xx159/Tim_mc/3a19ef6628ad55a586a8b27bd95a77b5_zps59f1c674.jpg
Damper upper bolts are facing the wrong way- they would hit the body not allowing you to get them out.
May be worth dropping beam to swap around now before more bits are bolted on.
timoth123
Ah brilliant! Thanks for the heads up on that Tom! Appreciate it!
timoth123
Been pottering along with a few bits over the last couple of days.
Got the engine fully stripped, after I tried the 4th different windy gun (heavy duty one from the heavy truck line workshop) to get the crank pulley bolt off, it finally gave in! Was plain sailing after that.
There was some pretty nasty looking scoring on some of the main bearing cap shells (2 and 4). I can't see any damage to the crank so hopefully all is ok there.
I've packaged up the pistons, liners and rods, crank and head which has all been sent to the engine builders to be checked over and the head refurbed. Bit worried about the head as there was some corrosion on the face. Fingers crossed it's not as bad as it looks.
Check out the crap around the liners. The bolt is a flywheel bolt some sort of size reference?!
aac17cbcf47ed24d023cd67550d234cb_zpse9ce
d1532dcee1a70704d7d2748aaff32cbc_zpsfc93
89f2453f3edf44f4a80380c8497d4dd4_zps00db
The main caps, you can see the scoring here.......
c83dc1f88a14ce795690968247bcd759_zpseda2
25e1536fbb43ee41f4c6f2ab0f34cf45_zps70b8
Here's all the parts waiting to go through the parts washer.
d3235253bcdc6af7628e8fc0894a79d4_zpsdec7
And how the block came out. Not as good as I had hoped. Anyone any ideas how to get this back to pristine clean? Some sort of blasting maybe?
a4323c871e60b3b6887d2a5ec5916d20_zpsb50a
Also anyone have a be1 gear knob insert that's not faded? Like the be3 one I have below. The be1 I have is too faded for my liking.
d2ae18b772a3c76df02ddc46a57027c8_zps944d
And.....
Anyone want these for free? Front Undamaged genuine wings and lowering springs. Going in the skip at the weekend if no one does?
Must be some use to someone?
40a5bb80d50c8cfa8ac801de5720384d_zps637a
ad1d36e8abc39a1d2eabf565f946549b_zps493f
I would gladly take the wings Tim, no chance you could box them up? Happy to donate beer token or even some trim or engine parts if i have anything you need.
No idea in your area, but i have seen parrs sandy brown has had vapour blasted, what the process entails exactly i'm not certain, but for an engine block you want to avoid abrasive particulates given the potential for carnage that could ensue if you miss the tiniest bit.
timoth123
Yeh I'd gladly box them welsh, pm me your name and address and I'll put it through parcel hero to see what it costs. It won't be much. I've just sent 44kilos of engine parts to South Wales pistons, and that only cost £23.
Shame I'm not going home to Tenby this weekend. Could have dropped them in.
Weser
I will take second dibs on the wings if it falls through with welshpug
