johniban
[Car_Upgrade] 1.9 Gti Rust Repairs And Bodywork
johniban
im just buying all the bits that are old and knakard like wishbones and driveshafts need to get it off the axle stands and rolling so i can spray it
Juttie205
Looks like your making good progress keep it up.
johniban
thanks juttie, im trying to get it all done before the next bhp show, so i can hopefully take it instead of the 106 or the rallye
johniban
Had a long old day today, fitted the engine again, and then found out the the 'gti6 205 exhaust' i bought is actually for an mi16 engine in a 205.
952BA0EF-9BD7-440E-A99B-C9589AE444DA_zps
6AB2237C-9AAF-4025-B321-6716ADBA77DD_zps
14D2DD94-7497-44B8-A70D-A8B18B1BB95A_zps
so that will be up for sale now, silly me to think it would fit...
anyway, engine back in, original gti6 manifold on and reangled/welded up.
and got on with finiishing the fuel system
i originally wanted the fuel regulator on the passenger side in the engine bay but i would have to route the fuel line from the drivers side to the passenger side, that would look messy so i have mounted it on the drivers side also made a start on the brake lines..
894B8FC6-2005-41E8-AB4F-4208122C2F13_zps
AFA891B0-8BC4-44AF-AB42-7471E6684835_zps
B53A097E-CD04-4525-9197-7CC92E916EDE_zps
7B0D1CC3-AB3A-4E07-BA94-338236621CC1_zps
johniban
3B02B943-E93B-4001-B569-B5BA71A2C68C_zps
link pipes made up to join carbs to regulator, and regulator mounted,
front bumper on and finally looking like a car again
C73232F9-8E63-43EF-8C23-230595380F49_zps
johniban
This turned up today, along with some extra parts like new wishbones and aux belt and tensioner
86931A44-A6E0-45F6-A6E9-4EAE07975A1F_zps
looks really good, not the lightest thing in the world considering it suposed to be a lightweight racing battery but still
johniban
also got a set of these from pug racing, recommend to anyone, not set up yet but that fit easily and feel nice and strong
3BF52154-73A4-48EA-BB75-639E1AAF6F1B_zps
jamie_1992
If you have done the linkages I would recommend changing the bushes for the bronze ones BBM do I did and there is no play what so ever
johniban
thank you for the advise i shall probably do this
johniban
started making up the exhaust today, got some 2.5 inch stainless tube and started making it up, relised i have probably angled the manifold to far so the exhaustt down pipe has a bigger angle than it should have, but it will work, i may have to get a pro to tig me up a decent down pipe but this will do for now.
even though i am running carbs i have added a lambda port and bung just incase i need it for setting up fueling, i then relised i had welded it on the wrong side doh! so i cant leave a lambda sensor in there as it will foul on the gearlinkages,
wish i had some stainless wire as it probly end up having to paint it as it will rust
143B5B8D-1B0D-4404-901E-E8DA7C33C80A_zps
FEFC6A4E-7944-4A2E-8D3B-61E672961E0B_zps
5B233A8F-9C5E-43DA-865E-EBC90BF8267C_zps
johniban
battery mounted in boot, have mounted a hidden cut of switch in arms length for security and possibly safety and to not make the interior look like its got aftermarket items fitted
3B1CEEBA-BFE4-40E2-82BA-BAA1C2D4C032_zps
johniban
really happy now i have power and lights, and engine turns over, strange earthing issues as rear washer pump activates with right hand indicator but ill sort that out
johniban
coilovers fitted, not my choice but its what i have for now, new wishbones, track rod ends, drop links brake lines and hel braided brake lines
7F81962B-D98B-43B8-B58D-28AE831137CE_zps
johniban
not sure if i have the brake flexi the right way around but it looks ok, just need some spring clips to hold the hose in place.
C7B2D9AA-02CF-48D3-BCF4-2A7FF5BA41BB_zps
no, that is very wrong.
wrong way up in the bracket, and wrong side of the strut, the unused bracket of the strut should have been a MASSIVE hint...
Edited by welshpug
That big kink in the downpipe will not help flow. If it has to be like that you would be better to use a swept bend in there rather than a sharp pipe join.
Here is one I made for my turbo car.
johniban
i do need to have a redesign on the down pipe, but i want to get the car up and running at the moment, them perfect everything afterwards
cybernck
Just a quick comment on recent injection reliability issues etc topic.
I often say that it's a shame most of 205 GTI's in the UK ran Jetronic engine management and many of you haven't experienced an 8v engine equipped with Motronic 1.3. They simply start up every time and under any conditions, idle perfectly, never stall and always rev-up without any hesitation of jerkiness. Until one of the electrical components fail, ofcourse, which again doesn't happen often.
Not much to do with the actual theme of this build, just my 2p worth in general :).
Anyway, back to the main topic and keep up the good work!
johniban
Got a new home for the gti last week witch is good, just spending time fitting it out, tools, lights ect,
E25C4018-F599-486E-8562-FE82F0744804_zps
decided now i have a proper place with room, im going to strip the 205 down to a shell, redo the repairs id done previously and get it painted up.
B70EE99C-DBB3-4ECC-8301-6D05694BF9D6_zps
3D59AF77-36B2-4071-A43B-C940167FFBC4_zps
plenty of room in here
C29F3B97-F599-487C-86EF-F36005F906B0_zps
front end strip down
CCC826F1-E0C6-4F91-BCB8-2356A4A33399_zps
johniban
Windscreen out, mirrors off,
couldnt get the door off as the bolts are seized :(
C242726F-4225-46C3-8C07-90682F7646EF_zps
All trim off and boot off, really heavy when trying to remove yourself!
30821A30-39AA-4C9C-A6A4-FEF0FFF668F4_zps
Really unhappy with the boot repair i had done previously but im unsure what todo about it
EA740AAE-2E6E-48D3-8330-C52EACFACDD6_zps
johniban
The seam sealer had cracked so i think im going to sand it down and seal it again
Then i removed the engine with everything attached to it, much easier this way!
9045393D-C941-4D05-94D6-68B9F8D5A9A8_zps
7D025C90-D470-4292-A35E-6A96815574FA_zps
johniban
All going to be stripped back down, powercoated or painted where possible and built back up, ready for some nice throttle bodies
johniban
Couldnt resist buying some shiny parts for it :) these were very expensive yet seem to be cheaper to buy brand new than second hand?
F0F66AEE-84A6-4E09-9236-DB9D223FF60B_zps
C20D2C97-0A87-4567-B2DE-BD3DDD399775_zps
5BA3EAAA-B366-4A83-9E0D-337C40135304_zps
really happy with them, and they just bolt straight on with no fuss
johniban
strut tops strengthened
2D9CAF65-DEA1-45DF-8AFA-E1D5196F0F72_zps
A5F0B7B1-3E69-4AF3-A2DD-FF79A18CB711_zps
4919B9E5-2B12-4D57-9881-581F6563BF26_zps
seam sealed, filled and smoothed out arch
2372667D-BE47-4AD4-A353-A4C2FC575FD5_zps
DIY spray booth
79A615C5-EB4B-4DEB-B14B-7C441731A576_zps
85697158-24E5-4651-9759-F11E2F2928FD_zps
C03FF4B6-458F-43C9-B429-8E64B7C59925_zps
7BADCA84-8C49-483E-9430-35F94FDE1674_zps
johniban
Engine fitted, started on brake lines,
420B4395-6C81-47D6-B87C-91C391FF1F9E_zps
D6D52AE3-D6A5-4E64-9432-9A1EE0DD6FCB_zps
46E8B72C-CA43-46B3-B00A-94064A1CFAC8_zps
70484120-1652-47DC-B357-FDA4D082E0FB_zps
this tool is amazing and cheap!!
Battery wiring sorted with a junction box
243D27C1-2FAD-46CF-9A80-36D563786C64_zps
31D87F22-0381-47E6-A205-68A2268100F8_zps
