johniban
[Car_Upgrade] 1.9 Gti Rust Repairs And Bodywork
johniban
Now as this is no track car and i want it looking as standard as possible from the outside, i didn't want an oil cooler on show, so i have a black mocal cooler, but then still couldn't decide where to mount it, so after alot of research i decided to mount it in the engine bay,
C1250FF7-6A83-401C-BE2E-A59F5F671707_zps
54248A09-99DA-4880-9158-DBAAEA2EF4F3_zps
Mounted to the strut tower and the inner wing, its not mounted solid so there is some room for a tiny amount of movement, think i may invest in some rubber mounts in the long run
johniban
So now after filling with fresh oil, coolant and petrol, getting the ecu connected up the laptop i uploaded the base map
8ED64099-3D4E-4D6D-95CB-8CA02F20C85D_zps
johniban
Switched on ignition, fuel relay clicked but no fuel pump....
Checked feed to the pump, nothing, checked earth all ok.
checked feed out of the relay, that was ok
The thick white wire on the brown multiplugs i assumed was going to the fuel pump but when checking resistance it wasn't, so i made a jumper wire to the pump from the relay and i had fuel..
bled the air out the lines and it started! lumpy as hell and back firing throught the throttle bodies,
After getting the firing order right on the leads it now runs alot better,
still runs lumpy but i think thats down to the ballance of the bodies
dcc
Bit of friendly advice, bin that adjustable fuel reg. Well done on getting it running.
Two cooling fans aren't really necessary in my opinion. I reckon you would be better to lose one then you can put the oil cooler in front of the rad.
I don't think it will achieve much where you have put it as there will be naff all airflow to it.
Agree with Tom there, I run a single 250w 306 rallye arrangement on my zx, no oil cooler, just a heat exchanger.
Also as Dcc says, no need for the adjustable fpr, more trouble than they're worth, there's never any need to alter the pressure from a fixed value.
Edited by welshpug
johniban
I have been told this before, but i don't really want to be spending more money on a fixed one if i don't have to, surely it will be ok if i dont touch it?
johniban
Only reason on having two fans is i wanted one controlled by an inline coolant pipe sensor just as a back up incase the ecu failed for what ever reason,
you don't need to spend money on a fixed FPR, just use the standard gti6 one you took off.
my fan control is 100% standard, no link to the ecu.
johniban
Thanks for the advice, id rather it be more effeicent at cooling rather than less effecient, cant see that having two fans will be a problem, they are there now.
As for the FPR i was advised to get one of the 'cosworth' style fixed ones but i already has this in a box waiting to go on, im sure if its fixed at a certain pressure it wont need changing?
johniban
How would i go about using the standard regulator? it wouldn't fit in the jenvey rail
I use standard rail and a Jenvey rail.
johniban
I'm using omex 600, it doesn't support 8 injectors, i could plump them in but its pretty pointless if i cant use them
johniban
Decided to take you guys advise on the oil cooler/fan set up and im very happy with the result.
Ditched one of the fans and sorted out a relay set up for it with heat-shrinked connections.
Moved the oil cooler down to the front of the car, welded on mounts to secure the cooler, just need to secure the hoses neatly
931C52FB-4697-45F4-A4D9-A0E7CA421CBB_zps
johniban
I wasn't going to bother with the slam panel, but it makes the front end come together more easily with the grill ect and ive folded the rear section down to hold in the radiator,
D98610AC-3FFE-4C0E-ABD6-7BDABA28F32C_zps
johniban
I bought an exhaust system witch wasn't so straight forward to fit as id have hoped!!
When i bought it, it was in one long length and dhl wouldn't post it to me so i had the lad cut it in half to post and i welded it back together when it got here.
So this is the rear box, apparently custom made for a 205 but both of the mountings are a really poor fit so they will be getting cut off and better ones welded on..
I am however really happy with the tail pipe size and look
2EF448B0-C5C3-4DEB-8E69-93698CBF8223_zps
Middle section welded back together..
D0DB6B76-CE60-4502-A9EC-C614DB71A2EF_zps
2166A3B2-7591-4E60-B19E-8A131D059B70_zps
B5013663-DD99-428C-B3AD-36FEDB6A1074_zps
johniban
I'm really impressed with the sound of it on idle, it sounds pretty standard, ive gave it a little rev and you can hardly here it, well over the sound of the throttle bodies anyway,
Im yet to test it on the road
johniban
Got down the garage on the weekend,
Fitted some gold heat reflective stuff to the bulkhead,
Also ive now moved the omex ecu, fuel pump relay and ignition relay to the glovebox and have moved the wiring loom to cut across the top of the gearbox and follow the rest of the loom up behind the nearside strut.
Much happier now its not near the manifold.
Also ive bought another slam panel as i wasn't too happy with the one i modified
A3C44C12-8EA8-44A9-A2EF-92DC4C37A0C2_zps
johniban
Ive also now fitted a gauge to the fuel pressure regulator to check the pressure is ok.
Ive made up a new small fan loom with a two pin radiator switch and a relay bolted to the slam panel, all heatshrinked, phone died at this point so couldn't get any pictures!
Neatened up the slam panel where i cut to fit the air filter with a file and Fitted some trim to neaten it.
656F0B01-5B3F-4548-9876-D4D0CF96B591_zps
No idea why it took in black and white
johniban
Now i have no way of using the original catch so i bought some Aerocatches.
I toyed with buying some cheap ones but i have used some before an actually snapped on of the pins off so genuine Aerocatches it was.
I'm not a fan of the ones that bolt from the top, maybe stronger but i prefer a more standard look so i bought the ones that bolt to the underside.
F385D4B7-2C67-4ED3-8B25-074729CC8F25_zps
F7A9C4FB-0403-4B98-99C9-9DB84D70FC72_zps
measured and measured, marked and marked
Cut out the first skin with a cone cutter and a small air cut of tool
Then cut the second skin with an air cut off tool,
96E75EF3-C050-4240-B49C-04E05B1B5307_zps
johniban
Sorry for the lack of pictures but basically they were a right ball ache to fit! now ive sanded down the top of the catches and applied a small skim off filler around the edge to blend into the bonnet skin,
Looked really good to me untill i gave it a quick spray of primer and noticed it needs further sanding and filling
B0101A61-20E7-4836-8A1B-0BA925C7476B_zps
johniban
second catch in, took photos this time, applied some epoxy to the catch face and the bonnet skin, prior to bolting them in,
4D2BA9AC-3E2E-4107-B270-F5C191C5A806_zps
johniban
Harden that i would have thought to get it looking perfect,
D5286DDE-6C3F-4A30-AA6E-2EEB474D90F4_zps
The top mounted aerocatches are much easier to fit.
